Old 01-29-2005, 02:42 AM   #1
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Default ej20G Q.
does anyone know how far the ej20g pistons come out of the block when they are at TDC?
or maby does anyone know the compretion ratio to a ej20G short block, ej20g pistons, and ej205 heads(usdm)?
kirill
mods if this is in the wrong forum u can move it...
snowman4us is offline   Reply With Quote
Old 01-29-2005, 01:00 PM   #2
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
heh uhh I'm no engine expert or anything but the EJ20G pistons don't come out of the block at all. since it is a turbo engine it should be dished. IIRC comp ratio is like 9.5:1
scobaru is offline   Reply With Quote
Old 01-29-2005, 03:59 PM   #3
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
actualy they do come out of the deck when they are at TDC. im puttin a ej20g bottom end into a my02 WRX and wanted to see how mutch the CR would change after...
kirill
Old 01-29-2005, 11:19 PM   #4
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Assuming you have the block just measure it. A cheap dial indicator will work fine. If you know(or measure) the CC of the piston and combustion chamber and gasket volume you can easily calculate compression ratio. Finding someone on this board that knows that info is very unlikely.
Scoobie Steve is offline   Reply With Quote
Old 01-31-2005, 12:15 AM   #5
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
i have all the tools to messure the CR and what not. but i just want to see if anyone knows how far the pistons comes out of the block...
Old 01-31-2005, 02:35 AM   #6
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Do a search for my name and read my previous EJ20G posts. I think someone said how far they come out, I don't remember.
As for compression, the EJ20G I believe has 8.5:1 with it's own heads. The CC of the heads has also been covered in one of my previous posts.
I can vouch that the pistons go out of the block, that's how they get the extra half a point of compression. I have the EJ20G sitting in my garage right now waiting for some love...
Chad
93 1.8/ej20g/2.2 hybred
subachad is offline   Reply With Quote
Old 01-31-2005, 08:25 AM   #7
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
thanks chad...yeah i have an ej20g witch is getting some love.
kirill
Old 02-01-2005, 10:59 AM   #8
subachad
Member#: 8488
Teal
What are you hopin to get out of it?
I'm only going for about 250hp, but I want it extra reliable for road racing and ease on the tranny. Here is my setup.
Stock 30,000 mile EJ20 block with freshened seals
Rebuilt EJ22 N/A heads with reground cams and very minor porting.
EJ18 intake manifold
370cc Legacy injectors
160 degree thermostat
TD04L turbo at 10-14psi
Stock WRX intercooler
Rx7 TT fuel pump
Stock 1.8 ECU with Greddy E-Manage.
2.5RS clutch and flywheel
I want this to last about 100,000 miles and see a LOT of track days before another rebuild. The tranny might not make it much longer, if so I'll put a WRX tranny in.
Chad
www.uniquemotorsports.com
Old 02-01-2005, 11:56 AM   #9
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
im doing this swap for a buddy of myne who spun the bearing in the #4 rod.
my02 WRX, WRX heads and all the other suff. just putting in a EJ20G w/ the ej20G gaskets...im just about to get the CR of the settup. im just trying to find the BORe and Stroke of the EJ20G. and the CC of the EJ205 heads (usdm)
Old 02-01-2005, 01:36 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Yes, it does clear the deck. No I haven't measured mine or my piston dish. The CR with the Ej205 heads will be higher than the 8.5:1 the EJ20G came with stock. The EJ20G heads have 57cc head volume, IIRC the EJ205 is around 45cc or thereabouts. Check EJ calcs for the exact number as I am too lazy to look it up or to reverse the math to find all the numbers. Bore and stroke for all EJ20's is the same for all generations...
Boost Leak Help EJ20G clean 93 Pre-2002 Factory Turbo Powertrain 5 06-08-2010 08:48 AM
ej20g td04 zeimet50 Private 'Wanted' Classifieds 4 06-02-2010 10:43 PM
Mines flashed EJ20G ecu, and ej20G engine harness liberty2000rs Engine/Power/Exhaust 1 10-31-2006 12:54 AM
EJ20G TD04 turbo, EJ20G intercooler xtian Engine/Power/Exhaust 20 07-18-2006 04:39 PM
Local FS: sedan spoiler, MRT TMIC for EJ20G, and EJ20G GC8 headlights annointed Tri-State Area Forum 3 05-10-2003 01:12 AM
Message Board Statistics All times are GMT -4. The time now is 10:58 AM.
