Old 01-29-2005, 02:52 AM   #1
Flip C
Member#: 55331
Default Useable mix and match?
So I know everyone says stay away from the EJ22-TT.
Obvious reasons of things being laid out differently in the US cars. Understand this.
Am I correct in assuming it has: Closed deck, cast pistons, forged rods?
Couldnt you take this. and use it as a building block? ver 7 or 8 heads.
Different exhaust manifold (since its setup for dual Ts) etc?
Is there something Im missing?
Flip C is offline   Reply With Quote
Old 01-29-2005, 01:49 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
eeek
there is no twin turbo 2.2
there is a usdm 2.2L t rated at ~165hp
and a jdm 2.0 twin turbo
the 2.2 has closed deck cast pistons and ??rods
Old 01-30-2005, 07:34 PM   #3
Flip C
Member#: 55331
Ahh , sorry bout that.
That was meant to be EJ20TT.
So back to original question. What is known about this engine?
Im really considering buying one to build up. IE not using the heads or turbos etc.
Old 01-31-2005, 10:49 AM   #4
BAC5.2
Member#: 43996
The Aggressive (tm)
You don't know about it..
The EJ20 twin turbo should have the same block as the EJ20G. I know of at least one member that chose the TT heads over the regular DOHC WRX heads because they were available, and he has had good results.
I would think you could just swap exhaust manifolds, and bolt it in like an EJ20G.
BAC5.2 is offline   Reply With Quote
good idea to mix and match FW and clutch?? Suberman Transmission (AT/MT) & Driveline 0 08-10-2005 01:24 PM
mix and match hks hiper and spt wrx110487 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-07-2005 06:15 PM
Can I mix and match the CWest and Wings West body kits? Cardwizz Interior & Exterior Modification 5 07-24-2002 01:01 AM
Mix and Match OEM and CWest Bodykit fukamoto Interior & Exterior Modification 3 06-16-2002 03:39 AM
U.S. 2.5 rs = mixed and matched....? suby ej25 General Forum Archive 19 01-24-2001 01:51 PM
