Old 01-29-2005, 08:19 AM   #1
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
Default CEL From Removing Gauge Cluster?
I took out my cluster to run some wires behind it, while it was out I had to move my car. I only moved it bout 10-15ft, when I reinstalled the cluster and started the car I had a CEL. If I pull the codes what code would it be for that if there is one?
Thanks, Frank
spoolinsuby is offline   Reply With Quote
Old 01-29-2005, 10:04 AM   #2
brunetmj
Member#: 8023
2004 2.5 RS
Honestly I am not sure. I mean you have interruption of the gas sender, water temperature and other things. Of course it does not matter really, unless of course it came back. Not likley to be any kind of problem Just have someone clear it. Autozone can do it.
brunetmj is offline   Reply With Quote
Old 01-29-2005, 12:59 PM   #3
909
Member#: 18776
Yup, since you moved the car with the speedometer disconected, you went into error. The wheels aren't allowed to turn without the speedo being hooked up. You will also find that other things don't work as well. It is a fail safe to keep people from tampering with the mileage on their car.
Reset the ECU, if it doesn't go away, drive for about 10-20 miles and it will self reset. It has been so long, i can't remember if it is mileage that gets rid of it or key turns. Sometimes they self clear after like 10 key turns.
909 is offline   Reply With Quote
Old 01-30-2005, 02:35 AM   #4
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
ok thanks for the help
Removing gauge cluster in 96? Local_Skater Newbies & FAQs 5 01-23-2007 06:21 PM
gauge cluster from a 93-97impreza w/tach, and sideview mirrors from 98 up w/elect. mcu81 Private 'Wanted' Classifieds 2 02-08-2004 01:56 AM
Removing gauge cluster reset odometer? beta Electrical & Lighting 2 11-29-2003 08:59 PM
Legacy Gauge cluster removal? Possible? czo79 Legacy Forum 11 09-19-2003 03:43 PM
CEL from boost gauge install, kinda austenf740 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-21-2002 03:18 PM
