Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 01-29-2005, 12:05 PM   #1
Sjerzey05sti
Member#: 75309
05 STI
CGM GT35r
Default Weird noise coming from my engine...
Last night I was driving my car home and kept hearing a weird noise under boost. It is like a howling, shreeking noise. Similar to when you have the window down alittle bit and air rushes through it and makes a noise. It isn't overly loud but loud enough as to where I can still hear it with the windows up. It sounds like its coming from the left side of the motor which is weird because I thought it might be the turbo. Anyone have any ideas??
Sjerzey05sti is offline   Reply With Quote
Old 01-29-2005, 01:13 PM   #2
BoostdBoxer
Member#: 53163
Just reseat the gasket on the Bypass valve and that will fix your problem..if that is the problem.
Cheers
BoostdBoxer is offline   Reply With Quote
Old 01-29-2005, 02:21 PM   #3
Sjerzey05sti
Member#: 75309
05 STI
CGM GT35r
I think you are right on the money there. But I think I need a new one. It looks like it peeled away from the intercooler. But thanks for the help you just saved me alot of time of searching.
Old 01-29-2005, 11:50 PM   #4
Sjerzey05sti
Member#: 75309
05 STI
CGM GT35r
I drove my car to work today and it took 6.5 gallons to go 57 miles. Do you think that if the gasket was leaking it would cause that? Or is the possible leaking gasket only one of my problems?
Old 01-29-2005, 11:54 PM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...fix the gasket, and go from there....
Old 01-30-2005, 12:06 AM   #6
powerslide23
Member#: 61956
2008 Tribeca
Pearl White Metallic
Already on a '05 STi? I wpuld think this is a warranty issue unless you abused it.
powerslide23 is offline   Reply With Quote
Old 01-30-2005, 12:18 AM   #7
Sjerzey05sti
Member#: 75309
05 STI
CGM GT35r
I'd rather just do it myself then waste a whole day at the dealer. Plus Miller Subaru sucks alot.
Old 01-30-2005, 12:31 AM   #8
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
Wow, that is worse than my mileage with the Green (11.7mpg)! But seriously, having a boost leak can cause you to run very rich.
blinguskahn is offline   Reply With Quote
Old 01-30-2005, 12:35 AM   #9
Sjerzey05sti
Member#: 75309
05 STI
CGM GT35r
I seem to still be making 1.2bar but that stock gauge isn't very accurate. But good to hear that its normal. Its way to cold out to be tearing things apart.
Old 01-30-2005, 12:38 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....so did you put a 'BOV' on it at some point???
Old 01-30-2005, 06:30 PM   #11
Sjerzey05sti
Member#: 75309
05 STI
CGM GT35r
Yes, but its a BPV and I replaced the gasket on it.
Old 01-30-2005, 06:52 PM   #12
2phless
Member#: 69343
2000 nothing good
slow
Join www.subarusti.org and share that info in the dealer rating setup they have.
2phless is offline   Reply With Quote
Old 01-30-2005, 07:23 PM   #13
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Ya got a leak there, somewhere....fix it asap.
Old 02-03-2005, 07:15 PM   #14
Sjerzey05sti
Member#: 75309
05 STI
CGM GT35r
Alright I put a new gasket on and put the stock "BPV" back on and its still making that howling noise. I didn't think it was just the gasket since I wasn't leaking any boost. But that gasket was shot. So any other ideas guys?? I checked everything and can't seem to find anything.
Old 02-04-2005, 04:38 AM   #15
ranmaru
Member#: 52050
i have the same prob but it is only at about 4k rpm and under very light boost. If i press the gas a little harder it stops. very confusing It is like a droning sound. Only when i shift gears and press the gas hard enough to just start to boost.
ranmaru is offline   Reply With Quote
Old 02-05-2005, 01:20 AM   #16
Subaru Gwinnett
Vendor
Member#: 23050
Check the silicone hose between the intercooler and throttle body. They make CRAZY noises when the hose clamp has slipped.
Quite often they will leak at exactly the same boost pressure, it's pretty funny sometimes.
Subaru Gwinnett is offline   Reply With Quote
Old 02-05-2005, 05:15 PM   #17
Sjerzey05sti
Member#: 75309
05 STI
CGM GT35r
The hose is pushed all the way against the IC and looks like its about a 1/2" off the TB where the stopper part that holds the hose from going over the front of the TB(if that makes sense). So as soon as I get home from work ill have to try moving. Thanks for all the helps guys.
Old 02-05-2005, 09:35 PM   #18
kool168
Member#: 61006
i am just wondering... why that hose will always lose? i tried to put it back twice already... and today when i was filling gas, so i check the enigne oil too. then i found the hose which connects TB and IC lose again..
kool168 is offline   Reply With Quote
Old 02-06-2005, 01:41 AM   #19
Subaru Gwinnett
Vendor
Member#: 23050
It's REALLY annoying isn't it. I blew 20+ mins on more than one tune session. Now I check that before I even start tuning.
Samco makes a longer hose, I believe the sexy pink one from SPT is longer too.
Generally we loosen all the IC bolts, pull it forward and tighten them back down.
Siegel
Weird noise coming from under my car...HELP ASAP subiace Factory 2.0L Turbo Powertrain 9 03-26-2009 07:37 PM
Weird noise coming from my front right brake orical154 Brakes, Steering & Suspension 9 04-28-2008 09:25 AM
Weird noise coming from the engine bay??? jmanSTI Texas Impreza Club Forum -- TXIC 20 03-27-2008 01:03 AM
Weird noise coming from the front passenger wheel area Night Kid Brakes, Steering & Suspension 3 06-04-2004 02:45 AM
Anyone hear a weird noise coming from engine bay in the cold weather? WRXVII Service & Maintenance 1 12-29-2002 06:13 PM
Message Board Statistics All times are GMT -4. The time now is 02:41 AM.
