Old 01-29-2005, 12:24 PM   #1
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Default 5v DC SPST NC relay - anyone know a source.
Can't find one anywhere.
turboICE is offline   Reply With Quote
Old 01-29-2005, 02:12 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Old 01-30-2005, 12:46 AM   #3
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Thanks their 5v relays are NO, like all the 5v I have found (or they are DT which I need ST. Seems no one makes NC (or dual) ST 5v relays.
Old 01-30-2005, 06:33 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Ok, try Newark Electronics- http://www.newark.com
Also what's wrong with using a DT relay and just connecting the NC contacts?
Old 01-30-2005, 11:19 AM   #5
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
My bust a DT would be fine, I can't find any 5v relays that have a NC contact that isn't a latching type.
Basically I can't find any 5v relays that will leave a circuit closed when there is no reference signal on the coil circuit and opens when there is a reference signal on the coil circuit. All the ones with NC contacts are DPDT I meant.
I can't use a solid state transistor relay because the reference circuit is on a different power source than the circuit I need opened.
Basically I want to disable a momentary on circuit from turning the car on when a laptop is already running (I will be using power from a USB port to indicate the laptop is already running.
Basically looking for relay 2 with a coil that activates on a 5v source.
Old 01-30-2005, 11:41 AM   #6
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
For instance I would use this if I could figure out how to make it work in the above circuit.
Old 01-30-2005, 05:45 PM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
mouser electronics, part # 528-9552-5 spdt, 5vdc actuated, flange mount, 20a contacts, $3.42
Old 01-30-2005, 06:30 PM   #8
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
That would work very well, if the one I am trying from Newark electronics doesn't work then I will definitely be trying that one.
Anyone know the source behind this pic? kavid dobayashi General Community 33 09-14-2008 11:31 AM
Does anyone know a source for Sta-Lube 75w90? leecea Private 'Wanted' Classifieds 0 08-04-2008 03:12 PM
Anyone know any source for Nissan 300Zx headlight units? Pipercub Mid Atlantic Impreza Club -- MAIC 3 06-03-2005 09:51 AM
Anyone know a source for Subaru electrical connectors? (DZ) Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-14-2002 07:10 PM
Anyone know a source for good Coilovers or Spring sets? BrysImpreza Brakes, Steering & Suspension 4 02-05-2001 05:53 PM
