Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 01-29-2005, 05:47 PM   #1
REDI-wgn
Member#: 38068
03 WRX Wagon
Default stock egt vs aftermarket
ive searched already so if you find something helpful please pint me without flaming me
my question is that besides location is there any reason why we would not wnat to use our factory egt with lets say a psi3 display system?
is the operating range different in the stock sensor that of the aftermarket or is it just the preciseness as with 5 wire 02 to 4 wire 02?
i understand with location it does not gauge acurately due to the distance from the echaust ports themselves, but this can be compensated for by simply running slighty cooler temps but staying withing the same degree change as someone else running theres closer to the ports( i hope you understand what i am trying to say)
i hope someone will be able to help me out here, i guess i am calling for the real specialists on this one
and oh yeah if i am in the wrong forum please advise me to move
Thanks in advance
Andre
REDI-wgn is offline   Reply With Quote
Old 01-29-2005, 08:16 PM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
If you still have the uppipe cat, than the stock EGT location is completely useless since it will be severely skewed simply by radiant heat from the glowing-hot cat. You might as well just put some blinking lights in your dash - they'd be about as useful.
nhluhr is offline   Reply With Quote
Old 01-29-2005, 08:34 PM   #3
REDI-wgn
Member#: 38068
03 WRX Wagon
what about with catless up-pipe ?
Old 01-30-2005, 12:39 AM   #4
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
in that case, your readings will be extraordinarily damped... I'm not clear what your aversion to putting the probe where it belongs is. . .
Old 01-30-2005, 01:46 AM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Scared of the install....
Old 01-30-2005, 09:36 PM   #6
REDI-wgn
Member#: 38068
03 WRX Wagon
as by damped i am not sure of wat you mean....
what i am saying is that the firther away from the exhaust port the cooler the gas will be(correct me if i am wrong). so if i do some kinna calculation to figure out the percentage loss(educated guess), and note the difference between highest and lowest temp, and compare to other wrx's, i should be in good shape providing i have the same temp range....
but im vering away from the topic....
i wanted to know what is wrong with the stock sensor besides location thats all becasue i am thinking about running the psi3 dispaly and then wbo2 with its own display and want to know if stock egt will be good enough for tuning purposes...
and U.Scotty scared of the install is the last thing....i did 4 installs of uppipes already which to me that requires the most work. (ps i am a technician for acura hence the not being scared part)
Old 01-30-2005, 09:37 PM   #7
REDI-wgn
Member#: 38068
03 WRX Wagon
forgot to ask if i do buy aftermarket egt, can i wire that in conjustion with the psi3 display to read there instead of its own gauge
Old 01-31-2005, 01:21 AM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....wow...
Old 01-31-2005, 06:35 PM   #9
REDI-wgn
Member#: 38068
03 WRX Wagon
P+P Stock Headers Vs Aftermarket Rokkit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 295 04-09-2007 04:16 PM
wrap on stock headers vs aftermarket w/ wrap? OvrClkdPmp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-31-2005 01:52 PM
Stock pads vs. aftermarket? bfodle Brakes, Steering & Suspension 17 02-14-2005 10:54 AM
Cobb headers - stock catback vs aftermarket chrhon Normally Aspirated Powertrain 7 04-03-2004 11:02 AM
Weights of stock exhaust VS aftermarket components twinz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-16-2002 04:09 PM
