Old 01-30-2005, 09:18 AM   #1
rebos123
Member#: 67669
2005 2.5 Hybrid WRX
evoIII 16G
Default Outside (Ambient) Air temp for '05 WRX
After doing many searches/reading it appears that the '05 WRX comes with an outside air temp sensor which is used for the climate control. My question is can I replace just the fuel/water temp gauge in my cluster with a gauge from either an STI or an OBS? Is the plug/harness for the temperature sensor present behind my instrument cluster to make this a plug and play operation?
rebos123 is offline   Reply With Quote
Old 02-15-2005, 07:35 PM   #2
rebos123
Member#: 67669
2005 2.5 Hybrid WRX
evoIII 16G
blump
Old 02-15-2005, 09:02 PM   #3
veightkiller
Member#: 78967
2011 335i
for the outside temp...it only display 2 digits..while your water temp is reading morethan 100+
veightkiller is offline   Reply With Quote
Old 02-15-2005, 09:46 PM   #4
WR^2X
Member#: 37617
I believe he is referring to the fact that the outside temp gauge is part of the water temp/fuel level gauge portion of the cluster in an STi. He doesn't want to make his water temp guage into an outside temp guage.
As for whether or not that will work, I have no idea. Probably easier to just switch to an STi cluster.
WR^2X is offline   Reply With Quote
Old 04-24-2005, 03:20 PM   #5
CletusTheDwarf
Member#: 27620
2009 Subaru WRX
where is this temp guage located?
CletusTheDwarf is offline   Reply With Quote
Old 04-24-2005, 04:09 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You would need to swap the entire cluster. It's not possible to swap the individual gauges, and the circuitry for the temp readout is part of the cluster circuit board.
Old 08-01-2005, 05:24 PM   #7
nate.the.great
Member#: 72031
So, if you swap your '05 WRX cluster for a '05 STi cluster, will the outside temp display work?
nate.the.great is offline   Reply With Quote
Old 08-01-2005, 05:32 PM   #8
CletusTheDwarf
Member#: 27620
2009 Subaru WRX
bump...where is this existing temp guage located?
Old 08-08-2005, 01:32 PM   #9
rebos123
Member#: 67669
2005 2.5 Hybrid WRX
evoIII 16G
the temp gauge I am refering to is located underneath the front bumper behind where your front license plate would be (if you have one). I don't have a camera handy to take a pic of the unit but I know it is a temperature sensor and may also be used for the automatic climate control system. Someone once said that the water temp gauge from an outback sedan has the digital outside temp gauge in it and this gauge could be swapped for the WRX water temp gauge. That's what prompted this question....
Old 08-08-2005, 08:43 PM   #10
Hagwag02
Member#: 63445
2002 WRX Wagon
That's a shame to have to go with an entirely new cluster in order to get a temp gauge, and then have to install the sensor and wiring as well.
What would that cost?
Hagwag02 is offline   Reply With Quote
Intake air temp of 02 wrx Skoloseven Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-06-2008 01:51 PM
WTB: Stock Air Intake for '05 STi theformula175789 Mid West Subaru Owners Club Forum -- MWSOC 0 07-20-2005 03:12 AM
WTT: '05 Aspen White STi Trunk & Wing for '05 WRX Trunk & Wing... STIcky WRX AWD Private 'Wanted' Classifieds 2 11-21-2004 09:57 AM
WTT: '05 Aspen White STi Trunk & Wing for '05 WRX Trunk & Wing... STIcky WRX AWD Private 'Wanted' Classifieds 11 10-21-2004 10:36 AM
