Old 01-30-2005, 05:36 PM   #1
USA1
Member#: 33390
Default Question about CATs and P0420 CEL
The P0420 CEL seems pretty common. In the CEL thread some people thought it could be an O2 sensor problem and not always a bad CAT.
Has P0420 ever been the result of a bad O2 sensor, or is my CAT the problem?
I've had a turboback with a hi-flow cat in the DP (on an '02 WRX) for close to 30K miles and just got this CEL. Do CATs go bad that fast?
USA1 is offline   Reply With Quote
Old 01-30-2005, 06:18 PM   #2
WRXVT
Member#: 17979
335i Blue
IIRC its usually the cat error, since there is a different code for the 02 sensor
WRXVT is offline   Reply With Quote
Old 01-30-2005, 08:05 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
It could be a winter fuel issue. Do the 'mechanical fix' and forget about it unless you get more/different CEL's.
Old 01-31-2005, 12:11 AM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
What is the "mechanical fix"? Does it work on rs's?
Tim Sanderson is offline   Reply With Quote
Old 01-31-2005, 12:29 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
...it is in 'quotes' for a reason....
Old 01-31-2005, 10:17 AM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You sly dog, Thanks.
Question about TBE and CEL UCDgogie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-20-2007 08:57 PM
Quick question about UP and DP cels Rayman21287 Mid Atlantic Impreza Club -- MAIC 2 07-28-2006 08:39 PM
Question about cats and ECU tuning soobaviator Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-05-2006 04:03 PM
Question about Tune and CEL 03WRX83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-08-2005 09:05 PM
Quick, easy question about Unichip and Cel dman918 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-30-2002 11:00 PM
