Old 01-30-2005, 09:43 PM   #1
Davenow
Member#: 23676
Default Drag racers, I seek your input for my motor swap :)
I have an 02 wrx with a wasted motor.
WHich will make me faster? Keep in mind that I am going to be doing an RA gearset, which will basically gear the car down.
STI 2.5 shortblock. TON of torque, a couple hp.
or
V7 budget longblock.
Same power, about the same torque, 8000rpm redline.
The torque would be great, but I am thinking the ability to spin freely to 8000rpm will make the car faster overall, especially with the RA gearset effectively shortening each gear, the extra 1000rpm will stretch the lower gears back out,for a tremendous gain in acceleration.
How far off am I??
Old 01-30-2005, 09:48 PM   #2
STipoweredWRC
Member#: 45449
93 FDLS1
5.7 liters>1.3 liters
what turbo are you planning to use?
STipoweredWRC is offline   Reply With Quote
Old 01-30-2005, 09:59 PM   #3
Davenow
Member#: 23676
VF22, the same one I have on my wrx now.
I dont have HUGE power goals. S0 the 22 is just fine.
Old 01-30-2005, 10:04 PM   #4
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
~v6
V6TurboTA is offline   Reply With Quote
Old 01-30-2005, 11:23 PM   #5
Apex Rex
Member#: 63218
Originally Posted by V6TurboTA
~v6
Apex Rex is offline   Reply With Quote
Old 01-31-2005, 12:02 AM   #6
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
funniest pic ev4r!
wrxtremeWGN is offline   Reply With Quote
Old 01-31-2005, 12:13 AM   #7
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
v7 is soooo smooth at 8k ;-)
Then again, a 257 short w/ worked heads and a good set of cams would make a screamer...
2 very different paths for speed...
DoctorNick is offline   Reply With Quote
Old 01-31-2005, 12:25 AM   #8
SleepinRex
Member#: 12449
22 would be teeny on the 2.5. If price is an issue, usdm 2.5. If you want finess, v7
SleepinRex is offline   Reply With Quote
Old 01-31-2005, 12:59 AM   #9
Timdog1650
Member#: 45516
MY04 STi
I would get the 2.0. At the top of 4th gera, at 8krpm, you'll be at about 110-115, which is pretty much where your vf22 is going to be able to take you in terms of trap speed at the MOST. Good luck dude.
Timdog1650 is offline   Reply With Quote
Old 01-31-2005, 01:06 AM   #10
STi_Guy04
Member#: 69461
2004 WRB/Sti
11.41 @ 123mph
what da hell is that a pic of!!!! LOL I might be stupi but I cant figure it out LOL haha
STi_Guy04 is offline   Reply With Quote
Old 01-31-2005, 02:46 AM   #11
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Will you get an ecu with the v7 or leave the avcs dead?
I say go with the longblock since theres so many beatdown miles on the heads.
santofontana is offline   Reply With Quote
Old 01-31-2005, 04:56 AM   #12
XT6Wagon
Member#: 524
04 STi
uhh... just run the EJ257 with a 8K redline.
XT6Wagon is offline   Reply With Quote
Old 01-31-2005, 05:16 AM   #13
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
Go with a V7, if ya can look for a Spec-C swap as they seem to be getting cheaper and cheaper
2002WRXSTi is offline   Reply With Quote
Old 01-31-2005, 06:21 AM   #14
V6TurboTA
Member#: 9090
09 Forester Gump
Honestly an 8k limit and a 5 speed would be perfect for.
I bet your mile time would benefit quite a bit too.
~v6
Old 01-31-2005, 06:57 AM   #15
happasaiyan
Member#: 37731
heh, exactly what i was thinking.
happasaiyan is offline   Reply With Quote
Old 01-31-2005, 07:10 AM   #16
TheMadScientist
Member#: 23717
2005 Big red
But he would need at the least cams to make any power up there with just the 257 SB. If he got a buget V7 LB he would all ready have the cams and good heads to spin to 8k.
Dave I say go the V7 LB I think you will be much happier in the end.
TMS
TheMadScientist is offline   Reply With Quote
Old 01-31-2005, 07:17 AM   #17
XT6Wagon
Member#: 524
04 STi
would he? Strange... My STi makes peak HP at 7,500, and I haven't gotten the limiter kicked up to 8K yet on it... just 7,500.
Cams would definitely make a difference at that RPM, but just getting a good turbo with plenty of turbine flow is all you need.
Old 01-31-2005, 07:45 AM   #18
V6TurboTA
Member#: 9090
09 Forester Gump
Your NASIOC Administrator
Yeah, cause theres no chance of blowing an STi motor by over revving it...
~v6
Old 01-31-2005, 07:46 AM   #19
Davenow
Member#: 23676
WIth the longblock, no ecu, AVCS dead.
with the 2.5, stock WRX cams, stock unworked wrx heads, no money for headwork or cams.
I think I am agreeing that the 8k redline will be awesome with the 5 speed, and the thing about putting me at 110-112 at the top of fourth sounds about perfect.
I ran JUST shy of 108 with my current setup, I am betting that the extra 1k redline will push me close to that 110-112 (coupled with the RA gearing)
And even though the 2.0 wont give me the torque that the 2.5 would, I am still going to effectively be putting a good bit more torque to the ground with the lower gearing anyway....
Old 01-31-2005, 07:49 AM   #20
TheMadScientist
Member#: 23717
2005 Big red
If he went with the 257. He would be using the stock WRX cams and heads the 2002 ones with shim over bucket valvetrain. I would not want to push that to 8k.
TMS
Old 01-31-2005, 07:50 AM   #21
V6TurboTA
Member#: 9090
09 Forester Gump
i think you should sell it, get a third job an get an STi
~v6
Old 01-31-2005, 08:42 AM   #22
Davenow
Member#: 23676
~v6
Not a chance in hell that is happening. If I wanted a GM product I would buy a camaro. ANd any 04 that I find will most likely have been beaten and who knows how it was taken care of. I will never buy a new Subaru again due to the GM quality. If They go back to Japanese ownership I will.
My next subaru will be a used L 2 door with a swap
My plan is to fix this, then once its paid off buy a Jeep (with the 4.0ho motor) for a daily driver. Keeping this as a toy
Old 01-31-2005, 09:29 AM   #23
happasaiyan
Member#: 37731
GM doesnt have share majority in subaru. they have a considerable share, but not controlling share.
Old 01-31-2005, 09:30 AM   #24
Davenow
Member#: 23676
Even so, have you seen the interior of the 05's?
GM all the way. Major design influence.
Old 01-31-2005, 09:34 AM   #25
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Yeah, that whole GM comment is kinda from right field...GM owns only 20% of subaru...
Need your help for my motor ... darko Built Motor Discussion 5 01-26-2009 02:07 PM
Registrars Seek YOUR Input on Event Registration rallygoddess Alaskan Impreza Club Forum -- AKIC 6 01-19-2009 12:33 PM
May I have your Input? : My 1st Tattoo.. skimmilk68 Off-Topic 54 06-10-2006 07:40 PM
looking for a shop to finish my motor swap 25rstautoxr Mid West Subaru Owners Club Forum -- MWSOC 89 08-10-2005 02:01 PM
Need input for my suspension setup...No, really, i need your help... ChristophWRX Brakes, Steering & Suspension 12 06-08-2003 11:22 PM
