Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 01-30-2005, 10:18 PM   #1
spoolindc2
Member#: 72972
2003 WRX Stage 2 HKS
Question keyless entry w/ turbo timer
Hey,
I just installed a greddy turbo timer in my car, now i have all the **** hooked up right, but i couldnt figure out how to make it so when the car is timing down, i can lock my doors from the remote. NOTE: this is not a factory alarm. its a keyless entry system. There has to be some wire i can clip so that i can time my car and still make use of the remote.... any help i know im being a nub.... :disco
spoolindc2 is offline   Reply With Quote
Old 01-30-2005, 10:20 PM   #2
sdogg3kgt
Member#: 38397
2002 Lovemachine
I'm interested in almost the same thing. When I warm up my car in the morning and lock it, I always have to use a spare key to unlock it because the remote won't work while the car is running.
sdogg3kgt is offline   Reply With Quote
Old 01-30-2005, 10:27 PM   #3
G3Red04WRX
Member#: 66611
2007 Trailblazer AWD
3LT Sandstone Metallic
Dont take it the wrong way, but why did you waste the money on a turbo timer?
G3Red04WRX is offline   Reply With Quote
Old 01-30-2005, 10:41 PM   #4
23b_Rex
Member#: 79394
02 gda
wrb
when i lock my doors with the key and the timer finishes my doors unlock... ***
23b_Rex is offline   Reply With Quote
Old 01-31-2005, 12:13 AM   #5
spoolindc2
Member#: 72972
dont take it the wrong way but obviously ur a newb.... first off a turbo timer can lenghten the life of a turbo since it lets the internals cool down.. if you just shut ur car off after mobbing it, the oil can turn into muck plus the bearings will wear out quicker... not only that but it has a built in voltemeter, and other cool features that i like...
Old 01-31-2005, 12:19 AM   #6
emnm79
Member#: 76909
ahem...
that would be correct, but...
The heat contained in the turbo charger will begin to vaporize the coolant at the turbo charger after the engine is stopped. This hot vapor will then enter the coolant reservoir tank which is the highest point of the coolant system. At the same time the vapor exits the turbo charger, coolant supplied from the right bank cylinder head flows into the turbo. This action cools the turbo charger down. This process will continue until the vaporizing action in the turbo charger has stopped or cooled down."
http://forums.nasioc.com/forums/show...urbo+timer+faq
"obviously ur a newb" lmao!! roflamingoS!!
turbonizer timeinators are funnay old school!
emnm79 is offline   Reply With Quote
Old 01-31-2005, 09:03 AM   #7
kingsubi
Member#: 19239
2011 WRX
ok - so i have ver2 sti (see sidebar) and don't think your little theory applies for my turbo and I also have keyless thats not working with my TT.
I know there is a wire somehwere - but in all the threads I found on a search it was on the 5th page and not very clear. (Just like this one will be...)
kingsubi is offline   Reply With Quote
Old 01-31-2005, 07:02 PM   #8
G3Red04WRX
Member#: 66611
BWAHAHAHAHAAAAA, i didnt even have to come back here to have the noobie owned. Someone else did it for me.
I was being serious when i asked you to not take it the wrong way. Turbo timers are essentially USELESS on a wrx with stock turbo. I was not trying to be a jerk about it, i was just curious as to why you bought one. I would have hoped with as much information is available on this site you would have looked into it here before going out and buying one, or at least started a new thread and asked about it. Might have saved you quite a few dollars if you had.
For your information, i own 2 turbo vehicles. my WRX, and a 240sx with a redtop sr20det swap. One of the first things i had installed along with the new motor was a turbo timer. The sr20 motor runs HOT, and the turbo is oil cooled. The way I drive my cars, i would be buying new turbos every other oil change if i didnt have one installed on it. On the WRX, since its water cooled, you can just turn it off and walk away, the cooling system does all the work on its own without needing the engine to run and waste gas.
If you bought the turbo timer for all the little "extras" thats cool too, i use the volt meter on mine from time to time, but how often do you really need to know the exact voltage in your car? If it starts, its obviously got enough juice, and you dont really need a volt meter to tell you if your alternators gone bad or battery has died...
So again, i sincerely apologze for offending you by asking you why you wasted your money on the turbo timer. Next time ill just be an ******* myself and call you a NOOB right from the start for buying something thats pretty much useless.
Old 01-31-2005, 10:17 PM   #9
spoolindc2
Member#: 72972
PWN3D
well, i dont have a stock turbo pal... im running a 20g w. some sti pinks and a utec amongst other things...i didnt take it the wrong way, and it was never my intention to start a thread that erupts fighting and bickering over who is smarter... all i wanna know is what wire to cut so i can lock my car from the remote... i dont need to know how much smarter you are than me....
respectfully,
Bryce.
Old 01-31-2005, 10:58 PM   #10
kingsubi
Member#: 19239
2011 WRX
dido - also interested (more so about a GC)
Old 01-31-2005, 11:05 PM   #11
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
respectfully,
Bryce.
does your 20g have oil & water lines? if it has water lines your turbo timer is basically useless. if not then it isnt. and *** is with all the scooby newbies trying to pwn each other?
adeliciouspizza is offline   Reply With Quote
Old 02-01-2005, 12:31 AM   #12
spoolindc2
Member#: 72972
just cuz my title says im a "newbie" doesnt mean i know nothing... all that means is that I havent posted a zillion times... i come on this board daily and read alot, but post minimally.... the 20g does have a water line, so i guess ur right u own3d me.... however, i was wondering, how does the coolant circulate through the turbo and cool it down after my car has shut off?
Old 02-01-2005, 03:33 PM   #13
kingsubi
Member#: 19239
2011 WRX
Ok - do not cut the green wire w blk. I did this as instructed on scoobymods and it works to lock the doors and turn on the alarm when the TT is still running.
BUT....
When you go to unlock the door it unlocks, key starts up the car. But the alarm is still on! meaning that the shock sensor is still active - found that out by driving around and the alatm starts going off. You have to turn the car off (TT off too) and then use the remote to lock and then unlock(disarm) the car and then start up again.
Well I am up for suggestions!
Old 02-01-2005, 07:09 PM   #14
G3Red04WRX
Member#: 66611
Emnm79 already answered what your asking in his post. Vaporization process, similar to the way you would distill water.
But, i was curious if you were running both water and oil cooled on your 20g? I was taking to my dsm buddy and he said that the 20g comes with oil only or oil/water cooled cartridges. This is where i will admit to asking the "noob" question if BOTH can be used at the same time if it has the oil/water center section, if you actually use both or just have the option to use one or the other.
Either way, if you are using the water cooled 20g and no oil is going thru your turbo to worry about, maybe it still would be best to just remove the turbo timer or at least not use it on a regular basis, and just turn it back on for the days that you really work the car and would feel better about letting it cool down.
I dont know what the color is but my best guess if you were to cut a wire to let the keyless work when the engine was running would be whatever wire carries the engine running signal to the keyless entry control under the steering shroud. Since you dont have the alarm you wont have to worry about the shock sensor tripping when the engine shuts down.
Old 02-01-2005, 11:26 PM   #15
emnm79
Member#: 76909
sorry if i was harsh on u, im wondering the same thing, for warming up my car on cold days, I dont feel like leaving the car unlocked and running, and im too lazy to use the key, and I have 2 remotes
Old 02-01-2005, 11:40 PM   #16
G3Red04WRX
Member#: 66611
Sounds like you need a remote starter, rather than a turbo timer. Dont even need to go out to your car to start it up and doors stay locked until you get to your car and unlock them. And, pretty much all remote starter kits include a relay to disable your alarm system if you have one so it doesnt go off when the engine starts...
Old 02-02-2005, 02:04 AM   #17
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
yea... Im sorry but this is something that really needed a little searching to find. I even posted how to fix this problem on my 05. It wasnt even that long ago. Im starting to see now the frustration of the older members of this board. Its not that people don earch but its when they go through all that trouble to post their findings and explainations and have people keep asking. Please use the search function.
http://forums.nasioc.com/forums/show...6&postcount=21
darksands is offline   Reply With Quote
Old 02-02-2005, 09:32 AM   #18
kingsubi
Member#: 19239
2011 WRX
well u are right in your last assumption - that is not even close to what my module looks like
So any GC owners want to speak up??
Its hard to hear us over all these blog and bug eyes!
Old 02-02-2005, 09:39 AM   #19
kingsubi
Member#: 19239
2011 WRX
Old 02-02-2005, 07:15 PM   #20
emnm79
Member#: 76909
i tried your mod, didnt work, lame.
Old 02-02-2005, 08:19 PM   #21
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
Its not MY mod. Its the mod that everyone else does if they want their keyless entry to work when Tubo Timer is on.
Old 02-02-2005, 08:34 PM   #22
emnm79
Member#: 76909
:P sorry, i didnt mean it like that, i meant its lame how it works for one application but not another, but now i understand its because for the timer you remove the key...
Old 02-04-2005, 12:42 AM   #23
spoolindc2
Member#: 72972
well fellas, I thank you for the forum link from darksands and I searched.. After I took apart my dash and saw that there is NO green/black stripe wire anywhere on that particular plug... I do have an 03, and darksands does have an 05.... WHat should I do?
Old 02-04-2005, 12:58 AM   #24
emnm79
Member#: 76909
check your pm
Old 02-24-2005, 11:07 PM   #25
BelvnAWD
Member#: 68363
2004 WRX
Nevermind....
BelvnAWD is offline   Reply With Quote
NH: Bunch of Good Stuff: HID, Turbo, WRX Keyless Entry, and More apkarian100 1993 - 2001 Impreza Specific Parts 18 06-09-2010 11:06 AM
Making Turbo timer work with your Keyless Entry Andreyk9 Car Audio, Video & Security 10 11-17-2009 11:20 AM
Reseting new keyless entry with turbo timer sponger Car Audio, Video & Security 1 08-30-2006 03:14 PM
Turbo timer and keyless entry yellowsooby Electrical & Lighting 0 02-06-2006 11:14 PM
will a turbo timer affect programming new keyless remotes? devin Electrical & Lighting 13 07-08-2005 02:03 PM
