#1 |
Member#: 57809
Okay i finally got a jdm cluster from 93-96 that will fit my L. And after looking at the jdm cluster i realized that a lot of wiring will have to be done, so i came up with a plan. I am going to just take the JDM gauges and swap them with my L ones. Ok so the jdm things are all on the opposite sides of mine. So i would be putting in a KPH tach, and my water temp and gas gauge would be going on the opposite sides so then gas would read water temp and the water temp would read gas. Its kind of messed up but i am lazy, since i am just doing this for looks anyway. So would there be any problems that occur besides the water and gas gauges reading their opposite readings.ITs kind of confusing,but i hope you get the idea of what i am doing.
Zach
#2 |
Member#: 3362
Vehicle:1985 I've wired a Few cars in my day |
That sounds pretty retarded. Wire it up properly.
Z |
#3 |
Member#: 57809
If that doesnt work then ill wire it up properly
#4 |
Member#: 22345
NESIC
Vehicle:2002 wrx 2 tone + 18x9's |
you're two opposite gauges may have different scales, such as the gas gauge may go way off the chart if its hooked up to the temp sensor signal, and the temp may read barely anything if its hooked up to the gas gauge.
#5 |
Member#: 57809
yeah i put everything back together and i am going to wire it up right my only question now is if its plug and play or if i have to start wiring a lot now.
Zach |
#6 |
Member#: 43539
Vehicle:95L 97L 03hedgehog 02 wag 180mph monster |
no t exactly plug and play but it isnt too hard email me and ill give you my number it is easier to explain over the phone i know exactly how to do it
#7 |
Member#: 15322
SCIC
Vehicle:1995 gf wagon Blue Green Metallic 340 |
Some of the guages bolt right in w/ no wiring. The conductive bolts contact the foil layouts to make the electrical connection. You'd want to confirm that the bolt arrangement is the same first though. I saw a mechanical speedo cable adapter for converting Km to miles from a vendor in the UK. Forgot where it is.
http://forums.nasioc.com/forums/showthread.php?t=313734 |
#8 |
Member#: 57809
thanks for the info guys
#9 | |
Member#: 57809
Thanks, Zach |
#10 |
Member#: 43539
hey wondering if you figured it out
| Thread Tools | |
| Display Modes | |
| v8 JDM cluster into 2005 WRX | Mohammadov | Electrical & Lighting | 1 | 03-31-2008 03:38 PM |
| Wire Guru's: Jdm Ej20 Into 93 Impreza 4wd (No E-Techs Please) | ScoobySnacksURhonda | Subaru Conversions | 4 | 09-25-2007 05:36 PM |
| 05 JDM Cluster into 04 WRX | Wrx1234 | Electrical & Lighting | 1 | 03-21-2007 03:40 PM |
| 93-96 JDM STi gauge cluster into a 96L | Farabomb | Subaru Conversions | 4 | 05-21-2004 10:28 AM |
| JDM SPEC gauge cluster for 93-96 impreza | turbocolin | Private 'For Sale' Classifieds | 25 | 04-16-2004 09:23 AM |
