Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 01-30-2005, 11:02 PM   #1
Member#: 80615
Default Problems with STI short block swap
So after having some issues with my stock motor (blown ring lands in 4th) I decided to swap in a STI shortblock. I had my heads put back to as new by a machine shop (redecked and new valve seals all round) assembled the motor and used Cometic gaskets and ARP heads studs. Dropped the complete motor into the car and now when I try to start it it cranks but does not start. The cranking sounds kind of lazy.
I checked the coils and it's sparking but the spark plugs are dry as a bone, there is fuel coming through the rail and out of the return so technically with all the cranking the plugs should be soaked no?
Any help from anyone would be greatly appreciated as I have pretty much tried everything I can think of.
ej20n00b is offline   Reply With Quote
Old 01-31-2005, 02:30 AM   #2
Member#: 5218
96L Most Over-
Developed Beater
Not if the injectors aren't opening.....Is everything plugged in? might've missed something......
Jay Storm
Old 01-31-2005, 02:46 PM   #3
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
almost sounds like the EFI fuse, but storm is right, injectors not opening
Hurley 2.5 WRS is offline   Reply With Quote
Old 02-04-2005, 11:41 AM   #4
Member#: 34184
02 WRX
Now with STI VII Swap
My vote is injectors as well.
redhat778 is offline   Reply With Quote
Old 02-04-2005, 07:58 PM   #5
Member#: 2175
I vote for rubber fuel lines being reversed at metal pipe going under intake manifold. Only cause I did it once. It certainly keeps it from starting.
Let us know, Brian.
LangstonSubaru is offline   Reply With Quote
Old 02-05-2005, 03:55 AM   #6
Member#: 61896
1998 2.5rs S/C
Easiest way to test the injectors is by taking a stethoscope, and putting it on the injectors. You should hear the injectors clicking, if they don't click then they aren't opening. Of course if you have an oscilloscope then you can diagnose it with that. I would personally check that the CPS (crank position sensor).
happyparrot is offline   Reply With Quote
03 wrx with sti short block and sti 6 speed tranny and 06 gsxr600 motorcycle platinum03wrx/sti Private Vehicle 'For Sale' Classifieds 4 02-16-2008 10:03 AM
question for 2.5 STI short block swap in my jdm sti JeremyRS Subaru Conversions 1 09-13-2006 11:12 PM
utec maps 4 stg4wrx w/sti short block swap wrx02racer Engine Management & Tuning 1 04-30-2005 02:26 PM
STi short block swap into WRX pegdrgr Subaru Conversions 97 07-20-2004 07:43 AM
What plugs and gap with wrx to sti short block swap? LiquidForce Subaru Conversions 5 07-04-2004 10:27 PM
