Old 01-31-2005, 10:28 AM   #1
bryan_johnson
Member#: 78987
Default Purpose of neutral switch?
Does anyone know what the purpose of the neutral switch on manual transmissions is? The ECU seems to monitor it for some reason. What happens when it is not hooked up (open) or jumpered (closed)?
/Bryan
bryan_johnson is offline   Reply With Quote
Old 01-31-2005, 10:40 AM   #2
AKGC8
Member#: 1305
2000 Impreza
Why don't they let us delete posts.
When I have time later I'll try to get back to this.
AKGC8 is offline   Reply With Quote
Old 01-31-2005, 10:45 AM   #3
BAC5.2
Member#: 43996
The Aggressive (tm)
You don't know about it..
Aren't you thinking about the Clutch switch?
If the car is in neutral, and the clutch is disengaged, the car will not start.
I would guess, that the neutral switch just gives the ECU more information as to what the car is doing. If it's going 85mph, and the engine is steady at 3500RPM, and the neutral switch is off, then everything is awesome. If the same scenario is happening, but neutral switch is on, then the ECU might have some trouble understanding this. It was designed to use a proper neutral switch, so you should hook it back up.
It's also related to cruise control. Neutral switch on = no cruise control.
BAC5.2 is offline   Reply With Quote
Old 01-31-2005, 11:55 AM   #4
bryan_johnson
Member#: 78987
The cruise control requirement makes sense. I am mating the soob motor up to a transaxle with no neutral switch (VW transaxle), but I don't have cruise, so I guess I'll just see what happens when I jumper it, or leave it open.
Thanks for your ideas.
Bryan
Old 01-31-2005, 12:26 PM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Read this post & my reply.
http://www.ultimatesubaru.net/forum/...neutral+switch
If you tie the neutral switch to the clutch interlock switch the ECU will have a relatively good interpretation as to when the car is in neutral and when it's not.
Legacy777 is offline   Reply With Quote
Old 01-31-2005, 12:27 PM   #6
GTScoob
Member#: 68602
02 STi Wagon
I've heard rumors that the ECU adjusts timing when the car is in neutral
It also probably ties into the ABS, cruise control, and starter interlock.
GTScoob is offline   Reply With Quote
Old 01-31-2005, 10:49 PM   #7
AKGC8
Member#: 1305
2000 Impreza
Okay, in the factory service manual, the only places I can find reference to the nps signal is with ignition during engine start and the idle air control.
The only 2 fault codes for NPS are high input and low input. The trouble symptom for both codes is erroneous idle.
So I doubt you'd have to much problems just splicing into the clutch switch and using that, may experience rough idle judging from the fault codes though.
Old 02-01-2005, 02:55 AM   #8
andys
Member#: 53455
2004 Forester XTI-RR
dark
my guess is that it's a for a combination of the idle air control and the air conditioning.
andys is offline   Reply With Quote
Old 02-01-2005, 05:29 AM   #9
AKGC8
Member#: 1305
2000 Impreza
I don't think it does anything for A/C. The ECU takes a signal from A/C and NPS and adjusts the idle air control solenoid valve accordingly(and from a number of other sensors as well). So when you're in neutral with the A/C running it raises the idle.
Old 02-01-2005, 10:20 AM   #10
bryan_johnson
Member#: 78987
Thanks for looking into that Eby. When I get this project running, I'll let you guys know how it worked out.
02-03 neutral switch and reverse switch the same as 04????????? fastlanerex Transmission (AT/MT) & Driveline 3 11-25-2008 03:00 AM
A faulty neutral switch causing misfire cels? BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-22-2003 10:36 AM
ECU neutral switch wire is triggering my alarm philip_g Car Audio, Video & Security 5 04-26-2003 12:16 AM
JC Sports Torque chip related at all to neutral switch engine light prob? MassholeGoneWest Normally Aspirated Powertrain 7 09-21-2001 01:27 PM
Remote car starters and the neutral switch on manual tranny. SilverSuby Car Audio, Video & Security 9 02-06-2001 11:13 AM
