Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 01-31-2005, 11:50 AM   #1
Member#: 36793
04 WRX
Default Gauges jump when AUX dimmer turned down
I have an 04 wrx. I intalled a set of Omori gauges into a din pannel. Every thing works fine for th emost part. My problems occure when I go and turn the dimmer down to around 1/4 or lower power. The neadles on the two elctrical gauges start flaking out. Jumping up and down. If I turn back up th einterior dimmer it subsides.
The gauges are all spliced into the clocks dimmer unit. Is there a electrical explamation and solution for this?
TopKatz is offline   Reply With Quote
Old 01-31-2005, 12:26 PM   #2
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Afaik, many electrical gauges only have 3 leads on each of the gauges: signal, (+) power, & ground. Connecting the (+) power & ground to the switched/dimmed supply to make the backlighting & needle dim & brighten along with the oem interior illumination means altering the voltage to the electronics that perform whatever measurement the gauge is supposed to do.
The reason is that electrical gauges with 3 leads are designed to be wired into cars with variable (+) supply instead of switched ground. Since Subaru uses switched ground for the interior illumination, you will either need to add a conversion circuit to power electrical gauges with 3 leads, or live with the fact that you can only use the constant illumination on them.
satrya is offline   Reply With Quote
Old 01-31-2005, 10:57 PM   #3
Member#: 5385
2012 WRX Base
Ice Silver
Does your gauge have separate wires for the lighting?
Or is it the 3 wire type that satrya described?
If it has separate lights and signal, FIRST you need to actually ground your gauges to a good ground NOT the illumination ground, because the illumination ground isn't ground, it varies from ground (lights bright) up to 12 volts (lights dim). I suspect this is why your gauges go batty when you dim the lights, they aren't grounded properly.
If you do have separate light wires on the gauge, you need to put one terminal of the light to a +12Volt line (probably the same line you use for the gauge power) and the other side can go to the "variable" or "ground" side of the illumination on the clock.
IowaRS is offline   Reply With Quote
VDO EGT gauge goes wacky when lights are turned on nicknaz Electrical & Lighting 2 09-20-2007 05:18 PM
So when to turn rotors and when not to turn rotors... Brahmzy Brakes, Steering & Suspension 2 01-11-2006 01:43 AM
05 STi gauges dimming more than usual when headlights are turned on. Moshpit552 Electrical & Lighting 3 10-20-2005 06:30 PM
HELP-installed dimmer mirror and boost gauge-running lights will not turn off cjsalv63 Electrical & Lighting 3 10-09-2004 02:09 PM
needle on gauge moves when turn signal is on Rickyh Electrical & Lighting 2 11-23-2003 11:22 PM
