Mid Atlantic Impreza Club
Old 01-31-2005, 01:52 PM   #1
LotusDriftx
Member#: 48528
Default Cars own me, wrx is an electrical nightmare apparently
yay for 3 cars that don't run right
So a few months back the wrx decided it didn't want to start one morning, with a fairly new battery in it and nothing left on I found this very disturbing, but ignored it.
Follow up with today and now its happened 3 times this week. My wife picked me up from the gym yesterday, and shut it off for maybe a minute. Went to turn it back on and nothing. Had to have a friend jump start us.
Same thing happens today.
So, whats the problem here? Almost new battery not taking the charge? 3 year old alternator on the fritz? Completely factory wiring has a short somewhere?
I'm so frustrated, but trying to keep sane.
LotusDriftx is offline   Reply With Quote
Old 01-31-2005, 02:04 PM   #2
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
probably a loose connection, it sounds like it's sitting cold and losing a contact... but when it's running, the motion of the engine is enough to keep it mostly connected
... which is a sucky answer because there's like no freakin' way to diagnose it other than very very slowly
Check Everything. What are you normally doing to get it started after it does this?
rogue is offline   Reply With Quote
Old 01-31-2005, 02:07 PM   #3
WRXWagon2112
Member#: 23524
2010 FXT
If all you've done is change the battery, I can't see it being a short (unless you've done some splicing of wiring harnesses or something).
It's not unheard of for new batteries to be messed up - uncommon but not unheard of. If you still have the old battery, try putting it back in as an experiment. Might want to take the new battery to a Sears or something for a quick test.
Hope that helps a little.
WRXWagon2112 is offline   Reply With Quote
Old 01-31-2005, 02:10 PM   #4
LotusDriftx
Member#: 48528
I have to jump it.
Tried push starting it with my wife yesterday, but apparently we can't push it up to speed enough to turn the motor over.
Old 01-31-2005, 02:13 PM   #5
JDM5LugHatch
Member#: 1312
'06 Integra Type S
Magnesium
possibly the alternator. Have you checked all your grounds?
JDM5LugHatch is offline   Reply With Quote
Old 01-31-2005, 02:14 PM   #6
LotusDriftx
Member#: 48528
I have never touched the wiring on the car, even the stereo system is stock.
I guess I will take the battery back to autozone later tonight. Unfortunately they didn't put me in the system for the warranty for some reason (they usually do, but I remember specifically on that occasion that they never asked for my info...wish I had said something) and I don't think I have the receipt. Well if its bad and they don't replace it, I will just not buy from them again (and george is going to give me back my altima redtop, bizzatch!).
Old 01-31-2005, 02:25 PM   #7
Deludedteg
Member#: 39858
2011 WRX
If you want to check your alternator, start the car, then disconnect the battery. If the car remains running, your alternator is good, if not, you might wanna get a new one.
Deludedteg is offline   Reply With Quote
Old 01-31-2005, 02:31 PM   #8
LotusDriftx
Member#: 48528
Yes, that was recommended to me last night, but I haven't got the chance to look at the car yet. I will test the battery, alternator, and look for any obvious loose wires tonight and get back to this thread with what I find. Hopefully its something simple and cheap (har).
Old 01-31-2005, 02:58 PM   #9
D_Block
Member#: 64127
2001 PY ITR, 2012 X5
on order
Bob? Gym?
Originally Posted by LotusDrift
Tried push starting it with my wife yesterday, but apparently we cant push it up to speed enough to turn the motor over.
AH, maybe you SHOULD be at the Gym
D_Block is offline   Reply With Quote
Old 01-31-2005, 03:31 PM   #10
banzai
Member#: 63926
Axis /RAW 2.2 Closed
deck EJ 20G stroker
I have to jump it.
electric fuel pump pnw3d joo!
banzai is offline   Reply With Quote
Old 01-31-2005, 03:48 PM   #11
LotusDriftx
Member#: 48528
The battery wasn't completely dead, BITCH!
Old 01-31-2005, 04:02 PM   #12
LotusDriftx
Member#: 48528
Originally Posted by D_Block
Bob? Gym?
Although I was just coming out of the gym, plus I am sick. Although according to brian I don't need an excuse as it was technically impossible...and that time me and my wife push started the 240 was just a figment of my imagination.
Why you guys gotta kick me when I'm down, go punch dave in the nuts or something.
Old 01-31-2005, 04:13 PM   #13
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Make sure the battery terminals are clean, and they are tigntened down good. It's very basic but had the exact same thing happen to a friend, her dad forgot to tighten the terminals. Sometimes the car would start other times it wouldn't.
EvasionOfTruth is offline   Reply With Quote
Old 01-31-2005, 04:15 PM   #14
LotusDriftx
Member#: 48528
I checked the basics yesterday when it wasn't starting. Terminals looked like they had a solid connection. Couldn't find any obvious loose connections anywhere.
Old 01-31-2005, 04:19 PM   #15
Nuc1earWinter
Member#: 44638
04 Sage 2.5 WRX
going to the pants party
You should switch the connections on the battery terminals around, that should fix something, if not prove entertaining
Nuc1earWinter is offline   Reply With Quote
Old 01-31-2005, 04:30 PM   #16
LotusDriftx
Member#: 48528
Well its definitely not the battery. My wife had to go to work today and the car wouldn't start, so she took a battery out of my other car. Goes to work, and now she can't come home, doh.
My boss is going to lend me one of those jump starter battery packs tomorrow, that will help in the meantime.
Old 01-31-2005, 04:33 PM   #17
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Is it not cranking at all?? If so check the trigger wire going to the starter, on PureEPI's car the wire came off and the car wouldn't start or even attempt to. On the RS its just a black plug with a female spade inside, the starter has a male spade sticking out for it to plug on to.
Although I'm not sure if it is exactly the same on the Wrx.
Old 01-31-2005, 04:42 PM   #18
NVAKeith
Member#: 26525
Sold 2002 WRX
2011 LGT Blue
I've heard of this test before. I'd try it on my 32 year old truck, but not on my WRX. Too many expensive electronics like the ECU that could get 'zapped'. If the car runs, swing by a battery store and have them test the charging system, takes a couple minutes and is usually free.
NVAKeith is offline   Reply With Quote
Old 01-31-2005, 04:47 PM   #19
LotusDriftx
Member#: 48528
Well it starts as soon as a new battery is jumpered to it though. So it seems like a problem with something draining the battery or with charging it. I guess if there was just a loose connection on the starter, a high enough current could overcome that loss possibly...
I didn't realize they could test it w/o taking the alternator out of the car, I will swing buy autozone and see what they say tonight.
Old 01-31-2005, 05:17 PM   #20
avatarr
Member#: 14010
'04 APS-ified STi
TopSpeed Tuned - Black
It sounds very much like something is causing the battery to drain and not maintain a charge. If you were here we could use an amp clamp to try to narrow it down. If you can find someone with a DC amp clamp you can try to track it down. Turn the car off, measure current on either battery lead, see if abnormally high (I would say anything that registers on the meter would be too high). Of course if no current is read that would point to a bad alternator but if the alternator was bad things would start going on the fritz as you were driving when the battery completely drains. I could probably help you diagnose this if you were local but long distance it will prove very challenging. You'd be better off going the autozone route to be honest.
Good luck.
-Jason
avatarr is offline   Reply With Quote
Old 01-31-2005, 06:07 PM   #21
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Every time that happened in one of my Fords it was the da**ed ignition switch, or a loose wire to the ignition switch.
Take the car to Autozone or Advanced Auto they'll check the charging system for free, at least that will give you somewhere to start.
wrx plus is offline   Reply With Quote
Old 02-01-2005, 01:05 PM   #22
LotusDriftx
Member#: 48528
Well since last night I have not had a repeat incident, so I'm tentatively calling this case closed.
I noticed when I was stuck at the gym that the battery connections were slightly loose, but I jiggled them and pushed them down and the car still wouldn't start. I assumed that wasn't the problem because of this, but I didn't think that maybe that loose connection had drained the battery to begin with.
Also everything came on fine in the car (stereo and lights), so I was thinking the connection was solid.
What I wasn't considering is the large load placed on the system when starting and its resulting current impulse. This would cause a huge voltage drop at the contacts due to ionization of the small amount of air between the terminals and the connectors. Then the car wouldn't start, but everything would seem normal inside.
Same kind of draining effect when the alternator is trying to charge the battery.
(wordy to try and make myself look less stupid for not tightening them all the way down in the first place )
So anyways I tightened them down solid, lesson learned.
(alternator tested fine)
and thanks everyone for trying to help me out, buster you win a cookie for being right.
Old 02-01-2005, 01:11 PM   #23
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Wink
Some would say that you don't have a problem. . .
isis is offline   Reply With Quote
Old 02-01-2005, 04:57 PM   #24
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
I want a large oatmeal raisin cookie!!!!
::crosses fingers it's fixed:: so I get my cookie
Old 02-01-2005, 05:00 PM   #25
carsnrockmusic
Member#: 58277
2011 Legacy
Grey
you've got the ****tiest luck....i feel for you...
carsnrockmusic is offline   Reply With Quote
06 WRX.. Is an aftermarket UP-PIPE worth it? lordizzy626 Newbies & FAQs 50 01-28-2010 08:18 PM
Can someone please explain this to me? Why is an 08 faster? Franko Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 01-13-2009 07:24 PM
electrical nightmare!! Subaru is clueless!!! hettchen Electrical & Lighting 7 08-16-2008 11:14 AM
having electrical nightmare!! Subaru is clueless!! hettchen Electrical & Lighting 1 08-11-2008 02:06 PM
results of the sport compact car ultimate street car challenge (yes there is an sti) sayaben Off-Topic 13 06-07-2004 01:39 PM
