Old 07-12-2001, 06:37 PM   #1
The Wraith
Member#: 7252
Default Need help with the Crank pulley
I want to add an underdrive pulley to my 2000 2.5rs. I can't seem to get the bolt off the original crank pulley. i was wondering. Is there a Pin of some kind holding it on? or is it reverse threaded or something? i broke two wrachets trying to get it off and i can't afford to break another. Please help me.
The Wraith is offline   Reply With Quote
Old 07-12-2001, 06:43 PM   #2
CSM101
Member#: 2805
2001 Impreza 2.5RS
BRP
Post
No key, standard threads (left for loose).
Best bet, load it with liquid wrench/WD-40 and use a big breaker bar 1/2 inch or bigger with a pipe on the end.
CSM101 is offline   Reply With Quote
01 LGT Tranny into WRX. Figured out the basics, need help with the rest. elhalisf Transmission (AT/MT) & Driveline 1 03-10-2005 07:50 PM
Need Help with the DRL's krazedant Electrical & Lighting 14 04-13-2003 04:11 PM
I need help with the Boostmonkey ChrisV-FL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-14-2002 12:04 AM
Need help with the exhaust! Elliot Normally Aspirated with bolt-on Forced Induction Powertrain 4 04-25-2002 06:22 AM
need help with the J&S knock sensor ChAi Normally Aspirated Powertrain 7 10-20-2000 10:32 PM
