#1 |
Member#: 48540
Vehicle:2005 Spec-V Sapphire Blue |
Hello,
How tight are the clamps on the radiator hoses supposed to be? I think I saw somewhere about measuring the length of the clamp where the screw goes through on the OEM style clamps. It's just that the wire clamps from the factory are a bit harder to "feel" when they are tightened down. Thanks! Jay
#2 |
Member#: 28716
SCIC
Vehicle:2006 STI |
Tighten with light to very moderate force until it won't tighten anymore, you should be able to feel it. Just don't go crazy and crank down on it.
#3 |
Member#: 48540
Thanks for the response... I noticed that the guys that tighten the clamps down at the factory must use an impact wrench to tighten the clamps down
. I'm thinking of just upgrading the clamps since I already see some cracks in the rubber where the hose has been clamped too tight. Jay |
#4 |
Member#: 10757
Vehicle:2013 BRZ Limited 6MT DGM |
If you see cracks in the rubber, I would just go ahead and replace the rad hoses with some silicone hoses the next time you change your coolant.
Calvin |
#5 |
Member#: 17315
International
Vehicle:MY95 Impreza 207C MY05 Forester 257X |
I tighten to a tolerance where I cannot twist the hose loose or unseat it in any way.
-paK +3 |
| Thread Tools | |
| Display Modes | |
| FS: NoVA: Subaru header gaskets, hose clamps, and silicone hose | adjasont | Engine/Power/Exhaust | 13 | 02-04-2008 10:10 PM |
| WTB: radiator hose kit, and coolant hose kitboth in blue. | AudiobahnSTI | Private 'Wanted' Classifieds | 0 | 03-30-2006 01:25 AM |
| Hose clamps in place of CV boot clamps??? | MDRex | Mid Atlantic Impreza Club -- MAIC | 5 | 01-14-2006 09:52 AM |
| so a heater hose clamp came loose yesterday, lost some coolant... | Big_Hitter | Texas Impreza Club Forum -- TXIC | 7 | 07-20-2004 11:12 AM |
| samco i/c hose install. do i need to use hose clamps?? | garie | Factory 2.0L Turbo Powertrain | 7 | 12-12-2002 12:27 PM |
