Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-31-2005, 05:09 PM   #1
norseone
Member#: 16350
B8.5 Audi S4
Default Another reason not to buy an HDTV
Now that I have one and an HDTV tuner the regular channels have grey boxes on the sides of the picture. Called letterboxing. I have a wide 32" LCD and all the regular channels are broadcast in 4:3 while my TV is 16:9. So my box adjusts the image to be shown in 16:9 and when it does it puts grey boxes on the outside of the picture and makes it look retarded.
However, the HD channels are cool. Discovery is realy good. ESPN does letterboxing though with black boxes on the side of the picture which have a big "HD" in them. And FOX, CBS, and ABC do the same. Makes me wonder why I even got an HDTV.
Anyone have similar problems??
norseone is offline   Reply With Quote
Old 01-31-2005, 05:12 PM   #2
Akirasoft
Member#: 2973
2015 X3 35i M-Sport
you should have the ability of changing the viewing mode for those channels. My sony does a great job with the modes. There is a wide mode where it simply stretches the image horizontaly, there is a zoom mode where it simply zooms in and you loose some of the image and a wide zoom that honestly does the best job, image is stretched proportionally so stuff in the center is nearly geometricaly perfect while things on the outside are stretched.
Akirasoft is offline   Reply With Quote
Old 01-31-2005, 05:13 PM   #3
TGC
Member#: 16255
2004 Mazda 3 5dr
2013 Mini Cooper S
Different brands do the 4:3 different. my samsung has black bars, while my parents sony has gray bars.
Why gray? i dunno, IMO it's stupid looking and takes away from the color of th picture.
might check with the brand and see if there is a way to change it in a service menu.
CHAD
TGC is offline   Reply With Quote
Old 01-31-2005, 05:14 PM   #4
Akirasoft
Member#: 2973
2015 X3 35i M-Sport
CHAD
gray is actually better, it reduces the contrast at the edges to reduce the chance of burn-in
Old 01-31-2005, 05:15 PM   #5
martel
Member#: 11178
2012 frontier
2014 Leaf
i use the stretch aspect for normal 4:3. it looks funky for about 10 minutes then you get used to it.
martel is offline   Reply With Quote
Old 01-31-2005, 05:15 PM   #6
Gundoo
Member#: 34112
i only like ot
as a friend
my 16:9 doesnt have that problem EXCEPT for some commercials during HD sporting events.
55in mitsubishi
Gundoo is offline   Reply With Quote
Old 01-31-2005, 05:15 PM   #7
Gcbinc
Member#: 28459
But I'm over
here now.
My hitachi will let me pick the color of the bars, gray or black, and I can stretch the edges of the 4:3 to fit the screen and you can barely notice that it's stretched...I don't mind.
you sure that you can't choose the colors of the bars?
GeoB
Gcbinc is offline   Reply With Quote
Old 01-31-2005, 05:15 PM   #8
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
no problem!
when I meet to get those lights from you, I'll bring my 27" sony CRT! It's got that blingin' 4:3 ratio you wanted
While I'm there, I'll haul away your pesky LCD too
rogue is offline   Reply With Quote
Old 01-31-2005, 05:16 PM   #9
WRXVT
Member#: 17979
335i Blue
you mean "another reason not to buy a widescreen tv"
WRXVT is offline   Reply With Quote
Old 01-31-2005, 05:17 PM   #10
VanillaEps
Member#: 8271
I have the same problem. Fortunately, my cable box has an option to 'stretch' the picture to remove the black bars. Unfortunately, the channels that do come in at 16:9 are cut of minimally on the ends. It doesn't bother me at all, but people always ask why the titles and credits are cut off from the screen.
VanillaEps is offline   Reply With Quote
Old 01-31-2005, 05:18 PM   #11
norseone
Member#: 16350
B8.5 Audi S4
I did check it. However when the HDTV tuner is plugged in the TV does not allow me to change the aspect ratio on the HDTV input. Which is retarded. I can only do it on normal TV. Inputs 1 & 2 and HDMI. Neither of the component jacks allows me to adjust the aspect ratio.
W T F is that?!
Old 01-31-2005, 05:19 PM   #12
norseone
Member#: 16350
B8.5 Audi S4
Gay ass TV, I am about to go ballistic here man!!!!!!11!
It says aspect can be adjusted on every input, but when I try to adjust it on either component it doesnt do s h i t.
Old 01-31-2005, 05:19 PM   #13
Mrhappy
Member#: 31973
2015 WRB WRX
2003 WRB WRX - bad engine
My sony will let me choose the color of my bars
Actually it won't but the service menu will.
Might be able to get into the service menu of your tv, which would void your warranty by the way. I'd just find the wide zoom mode and use that.
Mrhappy is offline   Reply With Quote
Old 01-31-2005, 05:23 PM   #14
norseone
Member#: 16350
B8.5 Audi S4
I can change the color of the bars through the tuner. But aspect ratio is a no go on the components. Which is where the HDTV tuner is plugged into, component 1.
I just called panasonic to find out whats up, automated system told me average wait time is 55 minutes.
Old 01-31-2005, 05:25 PM   #15
Thumper23
Member#: 11571
that's weird
I can change the aspect ratio no matter what I'm watching
Thumper23 is online now   Reply With Quote
Old 01-31-2005, 05:26 PM   #16
norseone
Member#: 16350
B8.5 Audi S4
Yeah tell me about it. The manual says that the aspect ratios are stored seperately for all inputs but it doesnt work for the component inputs. I dont know if its the tuner that is causing the problem or the TV is borked.
Old 01-31-2005, 05:26 PM   #17
aod
Member#: 7121
You should be able to justify any source except maybe DMI/DVI.
aod is offline   Reply With Quote
Old 01-31-2005, 05:28 PM   #18
TGC
Member#: 16255
2004 Mazda 3 5dr
2013 Mini Cooper S
oh...didn't know that. no worry for my DLP tho
Old 01-31-2005, 05:28 PM   #19
VanillaEps
Member#: 8271
W T F is that?!
That's my same problem. The Component Inputs won't allow me to change the aspect ratio. I'm sure if I do some research, I can get access to the tuner menu and mess around but that's getting heavy.
Old 01-31-2005, 05:29 PM   #20
norseone
Member#: 16350
B8.5 Audi S4
I dont think I need to worry about burn-in here, I have an LCD not a plasma.
Old 01-31-2005, 05:30 PM   #21
norseone
Member#: 16350
B8.5 Audi S4
Which TV do you have?
I have this one:
TC-32LX20
32" Diagonal Widescreen LCD HDTV with Built-In 4 Speaker Sound System and Included Pedestal Stand
Old 01-31-2005, 05:33 PM   #22
WRSport
Member#: 2060
00 2.5RS Coupe
01 black boxster hardtop
You need to use the stretch feature which your cable box should have.
On some manufacturers - hdtv component inputs on the tv are fixed and you have to use the source box to set the display aspect to your liking.
WRSport is offline   Reply With Quote
Old 01-31-2005, 05:34 PM   #23
VanillaEps
Member#: 8271
I have a rear projection Panasonic.
Like WRSport mentioned, I was able to 'fix it' using the source - the cable box, but its not perfect. It cuts off certain pictures that are in 16:9.
Old 01-31-2005, 05:34 PM   #24
norseone
Member#: 16350
B8.5 Audi S4
Okay, I will attempt to do so.
Old 01-31-2005, 05:35 PM   #25
WRSport
Member#: 2060
00 2.5RS Coupe
And I fail to see why YOU not being able to configure your equipment properly is a reason for others to not enjoy HDTV. It's finally here and it works flawlessly.
Another reason not to buy EBAY chinese products.... reddevil Off-Topic 80 10-17-2011 10:49 PM
Another Reason Not To Buy CHEAP TIRES Swisha Blast Tire & Wheel 8 06-26-2007 03:49 PM
To Buy an STI or not to Buy an STI? Opinions? J'sRex New England Impreza Club Forum -- NESIC 53 09-12-2005 11:40 AM
Yet another reason not to buy a rental car speaker General Community 37 08-27-2005 12:51 AM
one more reason not to buy an EVO TheRex South East Region Forum 21 07-03-2003 10:56 PM
