View Poll Results: port or No way!
Port the wastegate 13 72.22%
no way man! 5 27.78%
Voters: 18. You may not vote on this poll
Old 01-31-2005, 06:26 PM   #1
silver bQQst.
Member#: 70728
come by a subie!
04 STi, 06 B9 Tribeca
Default should I port my wastegate?
OK guys, I know that there has been discussions before regarding porting the wastegate, but I'm curious who thinks what??
c/n-
04 sti down pipe and cold air intake system, along with cold air = major boost creep=fuel cut=danger
during this really cold spell I was seeing 22 psi.
Whats your opinions?
silver bQQst. is offline   Reply With Quote
Old 02-21-2005, 07:22 PM   #2
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
dont port... Just dont. If its done incorrectly your turbo is screwed. I had one done by an 'expert' who shall remain nameless and it leaks.
dosage0 is offline   Reply With Quote
Old 02-22-2005, 08:02 PM   #3
sandiegowrx
Member#: 41743
i've got a vf34 w/ ported wastegate that won't hit target boost using AP.
sandiegowrx is offline   Reply With Quote
Old 02-23-2005, 08:15 PM   #4
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
Leave it alone....
Opie is offline   Reply With Quote
Old 02-23-2005, 09:11 PM   #5
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
C'mon, help fellow consumers out. Who ported your turbo?
SilverSurfer04STi is offline   Reply With Quote
Old 02-23-2005, 09:44 PM   #6
mdefalco25
Member#: 62985
2005 STi
Platnium Silver
I ported mine on my 05 STi when I put on the TBE from TurboXS. Not one problem in the extream cold and I hold boost just fine. If you follow the directions in one of the threads out here about how to do it you will see it is well worth it and not that hard at all! Spool time is much faster too by the way!
mdefalco25 is offline   Reply With Quote
Old 02-24-2005, 02:20 PM   #7
sandiegowrx
Member#: 41743
the problem I am having is that the wastegate is opening prematurely. I think this is due to the increased surface are of the larger flapper. However, I just read up on Perrins new boost solenoid and this seems that it will fix the problem associated with a larger ported wastegate flapper. It does not have to be setup as a bleed setup which is nice. It is fairly similar to the 3 port GM solenoid that people have beeen talking about recently.
Who can port my wastegate? vividwrx13 South West Impreza Club Forum -- SWIC 12 08-22-2005 02:03 AM
which shop can port my wastegate? sheizen Southern California Impreza Club Forum -- SCIC 4 06-28-2005 10:12 PM
Should I port my Green's Wastegate? antimullet Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 01-03-2005 05:14 PM
port my wastegate in nj ACLerok Tri-State Area Forum 2 05-14-2004 12:08 AM
Any SC dealerships that will and can port my wastegate? krazy Southern California Impreza Club Forum -- SCIC 0 03-31-2004 04:37 PM
