Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 05-04-2001, 04:22 AM   #1
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post Can't figure out whats wrong with my car
Finally found where the chirping sound was coming from. It sounded like a bird caught in a blender. Decided not to fix it.
That mysterious hesitation has mysteriously disappeared making it impossible to diagnose it. I'm hoping it was something left over from a bad ecu reset (or bad gas) on Sunday so it shouldn't come back again.
And I've still got to find and eliminate the minor creaks coming from the dash and ceiling panels. Not to mention the bumper lean so common on all our cars.
Anyone know how to get the throttle body off the car to clean it?
Revision is offline   Reply With Quote
Old 05-04-2001, 06:07 AM   #2
RacerinLSL
Member#: 1174
2011 Subaru WRX
Post
Revision - Where do you think the bird chirping sound coming from? What area of the car?
CHad
RacerinLSL is offline   Reply With Quote
Old 05-04-2001, 06:34 AM   #3
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
Andrew - use a wrench
Why not just use some cleaner spray it will be much easier.
rao is offline   Reply With Quote
Old 05-04-2001, 07:14 AM   #4
Revision
Member#: 242
MY05 PSM GGA !STOCK
Post
The chirping sound is coming from the crankcase breathers. Getting both vaccum and pressure from these lines depending on the stroke, only happens when warm.
I don't want to use throttle cleaner because I can't run the engine with the intake off. Better to take the whole throttle body off and clean it off the car. Maybe even do the intake runners as well..
(I nominate myself most anal Subaru owner in the MWSOC.)
Old 05-04-2001, 07:53 AM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Andrew - Sounds like time to trade the car in.
Old 05-04-2001, 10:43 AM   #6
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
Did you check you hood scoop for nests?
I dont know, Im pretty anal about the performance of my car. When something odd is happening SOS usually hears about it.
Midwayman is offline   Reply With Quote
Old 05-04-2001, 01:23 PM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
@ rao
I went nuts looking around for the cause of my chirping, almost ordered a fricken water pump (yes even though it's electric-- shaddup ) and then I saw someone comment that the UDP only take 90lb/ft. Uh oh...
Besides the chirping I have no problem. Belts are fine, and I've had way worse belt alignment on some fine (cough BEATERS cough) chevrolets I've owned in the past.
ColinL is offline   Reply With Quote
Old 05-04-2001, 06:34 PM   #8
Revision
Member#: 242
MY05 PSM GGA !STOCK
Post
Chirping is coming from the catch can for the crankcase breathers.
8Complex helped my fix the UDP a long time ago (last year).
Car still seemed rough, but maybe it was me being tired as the ride even seemed rough today.
Old 05-05-2001, 12:02 AM   #9
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Do you have an underdrive pulley? I think I overtorqued mine and warped it, and I have a chirping noise under acceleration.
Old 05-05-2001, 12:15 AM   #10
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
Uh, oh - Andrew has an unerdrive pulley and if there is potential problem caused by overtorquing, I'd bet good money that Andrew has the problem
BTW, Andrew, I just bought a new 4:1 gear reduction breaker bar that should twist to over 1000 ft.lbs - you can borrow it sometime
Old 05-05-2001, 12:41 AM   #11
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Mmmmmmm... 1000ft-lbs. of torque.... that reminds me, I should re-tighten my strut top-hat nuts.
need help figuring out what motors in my car subiefreak52 Built Motor Discussion 3 01-15-2010 06:40 PM
I finally figured out what's wrong with my Subie... woowoowoowoo Mid Atlantic Impreza Club -- MAIC 5 03-11-2008 08:35 PM
help! find out whats wrong with my car =[ Enriched Mid Atlantic Impreza Club -- MAIC 12 10-14-2006 02:30 PM
whats wrong with my car!?!?! HELP ME OUT GUYS!!! fifth. Newbies & FAQs 20 03-24-2006 01:13 AM
Guess whats wrong with my car from my description thread.. PaulRex Tri-State Area Forum 19 12-01-2004 12:13 AM
