Old 02-01-2005, 06:09 PM   #1
SanRemoRex
Member#: 62298
2008 DGM STi
MkII MR2 Turbo project
Question Factory Alarm buzzer is iffy
Anyone else having this problem? I have the factory alarm system on a MY04 WRX, and when I arm it, about 45% of the time it does the ::beep beep:: noise, but the rest of the time it either does a quick little weak beep or nothing at all. I'm assuming something is loose somewhere? The alarm works fine, just no arming tone. I like the little tone, and I'd like to to be consistent. Where should I look? There are like 3 horn/buzzer things under the hood so I'm really not sure where to start?
Thanks,
JD
SanRemoRex is offline   Reply With Quote
Old 02-03-2005, 04:05 AM   #2
caterpill
Member#: 27136
Cool
In the front of your radiator, after you take off your grill, there are three things. Two of them are your horns, dual tone, one high, one low. Those are round
( o ) ( o )
The buzzer is mounted to the left of those, should be obvious. I think it is even labeled "buzzer".
[] \/ ( o )( o )
\/ = hood latch.
[] = buzzer.
caterpill is offline   Reply With Quote
Old 02-03-2005, 08:44 AM   #3
SanRemoRex
Member#: 62298
2008 DGM STi
awesome, thanks, I'll check the connection next time it's more than 16 degrees outside.
Old 02-03-2005, 08:46 AM   #4
SanRemoRex
Member#: 62298
2008 DGM STi
also, in that case, what is the 3rd horn back to the left of the intercooler? the one that has to be relocated occasionally for certain part installs.
Old 02-03-2005, 09:28 AM   #5
skyhawk
Member#: 36255
04 WRB WRX
Drive 2 Work,Work 2 Drive
There are alot of threads on people with 04's having problems with their keyless entry buzzer not working. I haven't had any problems with mine though, knock on wood. The horn by the intercooler and the RH strut mount is for the alarm. The 2 in front of the radiator are for your horn button on the steering wheel.
skyhawk is offline   Reply With Quote
Factory alarm question That One Subie Car Audio, Video & Security 1 06-02-2010 05:52 PM
04 STi factory alarm to 05 Factory alarm blinguskahn Car Audio, Video & Security 2 08-05-2004 03:52 PM
Arming factory alarm while car is idling? hkwan Car Audio, Video & Security 3 08-06-2001 12:35 PM
Factory Alarm, Is it worth it? jbell303 Car Audio, Video & Security 7 03-19-2001 02:56 PM
