Old 02-01-2005, 06:47 PM   #1
DjStorm
Member#: 80751
2005 Wrx
Black, for now
Question Turbo Lag
I am having a problem with turbo lag in my wrx. I have an automatic with a VH 30 turbo. How would i go about getting rid of the turbo lag without using Nos.
DjStorm is offline   Reply With Quote
Old 02-01-2005, 06:58 PM   #2
kool168
Member#: 61006
get a smaller turbo
kool168 is offline   Reply With Quote
Old 02-01-2005, 07:44 PM   #3
El Supremo
Member#: 38388
or a larger displacement engine (2.2, 2.35, 2.5 shortblock)
El Supremo is offline   Reply With Quote
Old 02-01-2005, 07:52 PM   #4
DamienX
Member#: 66331
You could get a stall installed on your transmission if your using it for racing.
DamienX is offline   Reply With Quote
Old 02-01-2005, 08:11 PM   #5
clamdip
Member#: 18709
you could either get a better tune, or get a smaller turbo. whatever the case may be, the bigger you go, you will sacrifice for some lag. you could get STi heads and run the AVCS which could get you better low-end response, but then we're talking some $$$$$$$$.
clamdip is offline   Reply With Quote
Old 02-01-2005, 11:11 PM   #6
ncarn8
Member#: 71419
Port matching heat wrapping new ecu w/antilag and a good tune. Or get a new turbo.
Modding your torque converter to a higher stall speed will help off the line performance, and you wont feel as laggy. The fastest WRX in the world is an auto.
ncarn8 is offline   Reply With Quote
Old 02-02-2005, 01:41 AM   #7
DjStorm
Member#: 80751
2005 Wrx
Black, for now
I am a newbie at this, how would i set the stall speed to a higher level. I have no idea on how to do this.
Old 02-02-2005, 02:25 AM   #8
thesmokingman
Member#: 17751
2002 WRX Wagon
944 Turbo track
You need to have your torque conveter stall speed raised. This allows you to hook up later in the rev range, thereby allowing you more of a chance to be on boost. It can really minimize the lag issues you are feeling.
thesmokingman is offline   Reply With Quote
Old 02-02-2005, 04:00 PM   #9
DamienX
Member#: 66331
Or you could stand on the gas and the brake till you build full boost and let er rip.
Old 02-02-2005, 04:38 PM   #10
thesmokingman
Member#: 17751
2002 WRX Wagon
944 Turbo track
Eh... that's not smart on a stock tranny.
Old 02-03-2005, 03:25 AM   #11
ncarn8
Member#: 71419
Do a search on torque converters. Basically they are a liquid filled device with vanes that throw liquid from the centre to the outside creating more torque. Actually, i cant exlpain it. They are complicated. Go to an auto shop and get a modded one, and bolt it straight in. You cant set it or anythin, the stall speed is dictated by the angle of the vanes, the viscosity of the liquid etc, all physical charcteristics. Or you can mod your one you have, but i wouldnt bother. To see where your stall speed is now, roll along in 1 at about 5 kmh and plant it. The needle will rise up and where it hooks up is your stall speed. It is a rough test, but you can see the area it is in.
So see the experts and get a modded one fitted.
Old 02-03-2005, 10:20 AM   #12
pezman04wrx
Member#: 66558
You have no mod list, that would be of great assistance ... I'm guessing that since you're running a vf-30 that you've got an aftermarket up-pipe in there already ... (If not that'll definately help) ... Also, look up Deadbolt @ www.deadboltspeed.com ... You could always give their Monster Port and Polish a go, that would kill off a bit of spool time as well ... Good luck, and post up your mods, alot of things induce lag ... IE: Front mount intercoolers, headers, yadda, yadda, and then some reduce it ... Up-pipes, downpipes, blah, blah, blah ... You get the picture ... Pepole can help more if they know what you're running ...
pezman04wrx is offline   Reply With Quote
Old 02-03-2005, 03:29 PM   #13
DjStorm
Member#: 80751
2005 Wrx
Black, for now
A list of the mods that I can remember is i have a VH 30 turbo, perrin down pipe, perrin cat-back, perrin manual boost controler, turboxs twin horn blow off valve, and perrin cold air intake. I dont remeber if I replaced the up pipe or not.
Old 02-04-2005, 07:48 AM   #14
pezman04wrx
Member#: 66558
Well, check your up-pipe first thing ... If it hasn't been replaced yet do it now ... That'll help out alot with your spool ... Also, please say that you forgot to mention your engine management, if you didn't, and you have none, get some ... It will make a world of difference across the board ... It would litterally be a different car ... Then when all is well, if it's still not good enough, look up deadbolt for the P&P job ...
Old 02-11-2005, 10:05 PM   #15
VTsuby
Member#: 81369
2007 STI
not that you would want to set one up but google a bang bang system for a rally car
VTsuby is offline   Reply With Quote
More power in turbo lag than in turbo!HELP 99subi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-06-2005 01:47 PM
Test for Turbo-Lag, Downshift-Lag & Low-End 97itr153 General Community 10 05-28-2004 10:54 PM
MY00 has turbo lag.. er... rather.. NA lag..... Fitz New England Impreza Club Forum -- NESIC 7 04-03-2001 09:12 AM
Info on turbo lag IMPRZAMNSTR Normally Aspirated Powertrain 0 03-02-2001 11:02 AM
