Notices
Old 02-02-2005, 09:19 AM   #1
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Default 02-03 WRX ECU will run with what sensors minimally?
Well I am sure every RSt owner has contemplated a swap to a WRX ecu simply for the ease of reflashing and greater documentation, so I want to know what the WRX ECU will run without sensor wise....
obviously you'd have to switch over to WRX crank and cam position setups, use WRX ingition, and wire a multitude of things, but my question for you swap guys is.. what will the WRX ecu run without?
anything that doesn't require feedback I assume can be eliminated such as factory boost control, and stuff but what about EGR and related sensors? Is TPS compatible?
basically what sensors would the ECU have to see in order to just run minimally?
Todd
Hitokiri is offline   Reply With Quote
Old 02-03-2005, 05:55 PM   #2
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
IAC will bee an issue as the WRX uses PWM style and RS uses a stepper motor style.
Old 02-03-2005, 05:56 PM   #3
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
what about fuel tank pressure sensor and fuel tank pressure solonoid valve??? do you all have that hooked up???
Old 02-03-2005, 08:30 PM   #4
sick1.8t
Member#: 22345
2003 RSX
black
do you mind throwing constant CEL's? because things like not having the fuel tank pressure sensor (as above) will do that, but it will still run fine.
sick1.8t is offline   Reply With Quote
Old 02-04-2005, 09:32 AM   #5
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
To get it to run you'l need-
Crank position
Cam position
injectors
Spark Plugs
Starter
MAF
To get it to run without throwing any cel's and running well you'll need a lot more than that. O2 sensors and stuff, but those will run it ok.
speedyHAM is offline   Reply With Quote
Old 02-04-2005, 08:54 PM   #6
sick1.8t
Member#: 22345
2003 RSX
black
what will it need to run well, but but still with cel's? like O2 sensors will be needed to run well, but not the fuel tank pressure, etc...
Old 02-06-2005, 11:45 AM   #7
sick1.8t
Member#: 22345
2003 RSX
black
bump for above question
Old 02-06-2005, 03:12 PM   #8
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
you might want the Map sensor...since that controls overboost
HeMan1320 is offline   Reply With Quote
Old 02-06-2005, 06:04 PM   #9
sick1.8t
Member#: 22345
2003 RSX
black
water temp i would assume also? what other engine sensors does the 02+ wrx have? i'm more of a obd I guy...
Old 02-08-2005, 07:11 PM   #10
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Speed sensor
MAP
Front O2 sensor
TPS (I'm not sure if they are compatible)
Fuel pump controler will have to be wired in
I think those- along with the above list will get it running quite nicely. Lots of CEL codes, but those are just there for fun anyway. I can't say for sure that this is a complete list, but it's pretty close at the least.
It will run ok without the coolant temp sensor hooked up, but it might throw the ECU into limp mode after a while. I haven't tried it for long enough to know for sure.
Old 02-09-2005, 04:43 PM   #11
sick1.8t
Member#: 22345
2003 RSX
black
what does the ecu use the speed sensor for?
Old 02-17-2005, 08:15 AM   #12
sick1.8t
Member#: 22345
2003 RSX
black
i bet the knock sensor would be a good idea too.
Old 02-17-2005, 08:53 AM   #13
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
ECU uses the speed sensor signal to keep track of your speed, nothing performance related (except top speed governer). If removed it will (after a few miles) put the ECU into safe mode. Safe mode you will only get 7 psi boost and the rev-limiter kicks in at ~4K. It's no fun.
Old 02-17-2005, 11:31 AM   #14
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ecu also limits boost in first gear via the speed sensor
speedy makes an important point
it will run w/o all the sensors
but be in limp mode which is not acceptable
Old 02-17-2005, 01:57 PM   #15
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
I would also check to see how many plugs go into the ECM too. You may want to check that because more than likely the RS' ECM has 3 plugs and the WRX's has 5 so you will more or less be SOL.
Z
Zephyr is offline   Reply With Quote
Old 02-17-2005, 07:10 PM   #16
dentprone
Member#: 18588
1999 busted car
silverthorn
will the ecm allow the engine to start without the airbag module connected? i still cant get my car to run..its goin on 3 months of saturdays now.......man i suck at this swap stuff....
dentprone is offline   Reply With Quote
Old 09-18-2005, 11:54 AM   #17
sick1.8t
Member#: 22345
2003 RSX
black
i'm interested in using a wrx ecu (so i can use utec) on a obdI ej20g engine, in a obdI car. it will take lots of wiring but it looks like it may be possible.
so far this is the sensor list right?
Crank position
Cam position
injectors
Spark Plugs
Starter
Speed sensor
MAF
MAP
Front O2 sensor
knock sensor
water temp sensor
would things like a boost controller (bypassing the oem boost control system altogether) and the utec allow the speed sensor to not be used, so that i can get around the limp mode mentioned above?
WTB: oem wrx fuel rails,02-03 wrx ecu gc835 Private 'Wanted' Classifieds 4 07-29-2006 11:57 AM
WTB:STOCK 02-03 WRX ECU or any aftermarket ECU for WRX 02-03 SpoonTypeR Vancouver Impreza Club Forum -- VIC 17 11-25-2005 10:48 AM
SoCal FS: My Ecutek ECU for your stock 02-03 WRX ECU thebusiness999 Private 'For Sale' Classifieds 10 06-15-2005 05:17 PM
Wanted: 02-03 WRX ECU Fat Tits Tri-State Area Forum 6 10-08-2004 12:47 AM
02-03 WRX ECU Connectors or Harness shermtek Private 'Wanted' Classifieds 0 04-22-2004 07:33 PM
