Old 02-02-2005, 02:06 PM   #1
guinsu
Member#: 18756
2002 WRX Wagon
Default 2.0 vs 2.5
I was just curious what made people in this forum upgrade their cars with USDM STi2.5 motors or JDM 2.0 motors (specifically the v7 and v8). What would make someone favor one choice over the other? Is it just whichever you get cheaper? I am contemplating upgrading my WRX wagon for more power at some point but also one something that works well as a complete package.
guinsu is offline   Reply With Quote
Old 02-02-2005, 09:10 PM   #2
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
You would be happy with both. I say get the one you can get the better deal on.
RS_to_WRX_swap is offline   Reply With Quote
Old 02-02-2005, 09:14 PM   #3
pr0driveX
Member#: 23207
2011 WRX 5-Door
I would imagine the USDM swap would be harder because of the wireless throttle, and perhaps the ECU just not being plug and play. Plus, JDM engines are more powerful right off the bat.
pr0driveX is offline   Reply With Quote
Old 02-02-2005, 09:34 PM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
It comes down to what you want a rever or torque...
Old 02-02-2005, 10:26 PM   #5
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Could not have said it better myself totoherbs!!!
DuoMaxwell is offline   Reply With Quote
Old 02-02-2005, 10:46 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
both are great...I would go with the EJ257 for the torque, so long as the drivetrain can handel it...otherwise get the top end of the EJ207 with forged pistons.
Old 02-02-2005, 11:07 PM   #7
guinsu
Member#: 18756
2002 WRX Wagon
Hmm.. so the throttle and ECU are easier to wire up for a JDM into a WRX? That would be a major consideration. I figure either would have more torque than I have now with the AVCS and all. As for drivetrain, I have a 5MT with RA gears.
Old 02-03-2005, 05:28 AM   #8
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
why forged pistons with the 207 and not the 257?
i blew my 20g now have a ej257 with interals.. i am selling off the internals and i might sell off the 257 and get a 207... who knows.
and i dont know why..
scoobyimpreza is offline   Reply With Quote
Old 02-03-2005, 12:32 PM   #9
totoherbs
Member#: 7321
.... 122 IggPoints
I belive its cost.. the ej257 is subarus new world motor.
Old 02-03-2005, 02:09 PM   #10
AdamRX
Member#: 67601
'08 WRX Sdn
Slvr
Im lost...I have been going through the various threads about this and that swap.
I want an all out street machine that can really move from the line. I'm thinking of ver8 spec C and 6spd tranny in a '02 WRX. Since its twin scroll ( I belive only the ver8 are) it will have great low end. Is the top end loss that bad in comparsion to a bigger turbo on a stock 02 WRX engine? Can you not upgrade the turbo like most other Subie cars, er WRX?
-or-
Would running a 2.5 with a bigger turbo and 6spd give me the best of both worlds, stong low end and top end. As you can see I want to be fast of the line AND have the ablity to go all out. If I had to pick one, I perfer off the line speed over top end...
I just dont like waiting for the turbo to spool up. Out of the two (twin scroll, or 2.5) engines which would get me going the quickest/strongest? I know it will depend on the turbo, but in general. Bigger displacment can add faster spool, I believe? However between a ver8 and a 2.5, I dont know, or maybe understand which would out do the other...
PS: Whats the ver9 engine all about? Twin scroll as well??
AdamRX is offline   Reply With Quote
Old 02-03-2005, 04:05 PM   #11
totoherbs
Member#: 7321
.... 122 IggPoints
First its fast... second you can upgrade the turbo, but there arnt many options. Seach on twinscroll for more info. This motor is 100 times better then a wrx motor with or with out a bigger turbo.
No... unless you go realy big witht he turbo... gt30 or bigger.
Not much is known about the ver.9s yet. I belive it is a twin scroll.
either option is a good way to go... neither is realy that much better then the other. The 2.5 is a nice puller and the 2.0 is a high flyer. Realy do more research before you spend any money... months worth of it.
Old 02-03-2005, 04:22 PM   #12
AdamRX
Member#: 67601
'08 WRX Sdn
Slvr
I dont plan on doing anything until late spring, so thats why I've started lurking around here...
"High Flyer" meaning, revs? So, its takes the high revs to get the pull, whereas the 2.5 has the pull without the need for high revs?
Ver8 Spec C much better than ver8?
Does anyone have info on the ver9?
Thanks for the help, totoherbs
Old 02-03-2005, 04:28 PM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
Ya, revs. Its all in the way you drive and what you like... The spec C has a different turbo and some head parts; depending on what you want it may or maynot be worth it to spend the extra money on it.
Old 02-03-2005, 04:38 PM   #14
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
That isn't quite right. The 2.5 will make more power down low, at the expense of peak power. The 2.0 has a larger power potential than the 2.5 because of it's stronger internals and better cams and heads.
For high power, 2.0 > 2.5
That said, it still comes down to preference of driving style, because at the power levels where the 2.0 makes more power than the 2.5, you're already in ludicrous mode.
I prefer the 2.0
Capt Crunch is offline   Reply With Quote
Old 02-03-2005, 04:46 PM   #15
AdamRX
Member#: 67601
'08 WRX Sdn
Slvr
I noticed! but read that you looking for more...
I just want to put the pedal down at ANYTIME and move. Not wait forever for full boost, nor always downshifting to stay in my powerband.
I like to feel the pull right from start to end...
Old 02-03-2005, 04:48 PM   #16
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
get the 2.5 then.
Soon2Bgreat is offline   Reply With Quote
Old 02-03-2005, 04:54 PM   #17
Capt Crunch
Member#: 10852
Originally Posted by Soon2Bgreat
get the 2.5 then.
ditto.
Old 02-03-2005, 04:58 PM   #18
AdamRX
Member#: 67601
'08 WRX Sdn
Slvr
really...Im still gonna look for more info on the twinscroll
Thanks for the advice
Old 02-03-2005, 05:07 PM   #19
totoherbs
Member#: 7321
.... 122 IggPoints
Twinscroll will more likely cost you a good deal more then a 2.5 block.
Old 02-03-2005, 05:26 PM   #20
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
and it wont be a "put the pedal down and move anytime" turbo's just dont work that way. even with the twinscroll.
Hurley 2.5 WRS is offline   Reply With Quote
Old 02-03-2005, 06:42 PM   #21
Capt Crunch
Member#: 10852
yeah, twinscroll isn't really "all that." In terms of instantaneous response, there is no replacement for displacement.
Old 02-03-2005, 08:52 PM   #22
AdamRX
Member#: 67601
'08 WRX Sdn
Slvr
The reason why I was leaning towards a twin scroll setup, is because I just always thought it to be SIMILAR (in a way) to a twin turbo. I guess I can laugh at myself for that...
Twin Scroll comes with a vf37 or 36, how is the lag compared to a TD04 on a stock wrx, or a vf34 (cobb 2.5) setup?
2.0 vs 2.2 vs 2.5 ? Kaldar142 Built Motor Discussion 2 09-19-2007 09:36 PM
2.0 vs 2.5 STi Geb General Community 59 12-28-2003 06:04 PM
2.0 vs. 2.5 emissions C-daleRidr STi Forum Archive 4 01-31-2003 02:36 PM
Why turbo charge 2.0 vs 2.5? triXXXter Normally Aspirated with bolt-on Forced Induction Powertrain 10 07-31-2001 12:38 PM
Why turbo charge 2.0 vs 2.5? triXXXter Normally Aspirated with bolt-on Forced Induction Powertrain 6 07-30-2001 12:58 AM
