Vancouver Impreza Club
Old 02-02-2005, 06:32 PM   #1
Deziwoo
Member#: 53829
02 wrx
white
Default CAI on a wrx
so i was just talking to some ppl in the 2.0turboed section of NASIOC
and some ppl are saying that the CAI on a rex might not be the best idea.... i dunno but i'm gonna have a TurboXs EM system.....
just wonderin wut ppl here have to say? anyone here have one on their rex?
thanks guys
dez
Deziwoo is offline   Reply With Quote
Old 02-02-2005, 06:34 PM   #2
fukamoto
Member#: 13339
2013 BRZ
No point replacing the intake system off the WRX; if anything, just put a K&N filter. I believe a CAI caused the WRX to run too rich or too lean. I forget. Happy Days told me a while back
fukamoto is offline   Reply With Quote
Old 02-02-2005, 08:41 PM   #3
veightkiller
Member#: 78967
2011 335i
and using a CAI that's located underneath yung fenders might get wet and water might run into ur engine just a precaution... for the rainy days co'z u live in raincouver
veightkiller is offline   Reply With Quote
Old 02-02-2005, 08:59 PM   #4
tora
Member#: 5851
09 Forester XT
+ NA Miata
Yup, don't bother with a CAI.
tora is offline   Reply With Quote
Old 02-02-2005, 09:14 PM   #5
Deziwoo
Member#: 53829
02 wrx
white
awww shoot........ i've been running with one for a while now!
crap
time for a short ram i guess
Old 02-02-2005, 09:22 PM   #6
Deziwoo
Member#: 53829
02 wrx
white
anyone sellin one? teehee
Old 02-02-2005, 09:43 PM   #7
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
Um, short ram isn't considered any better. Best to stick with stock.
AllWheelDrift is offline   Reply With Quote
Old 02-02-2005, 10:19 PM   #8
fukamoto
Member#: 13339
2013 BRZ
Hydrolock
Old 02-02-2005, 11:10 PM   #9
Deziwoo
Member#: 53829
02 wrx
white
AH CRAP!
nothing i ever do is right! lol
Old 02-02-2005, 11:13 PM   #10
kool168
Member#: 61006
thanks guys
dez
http://forums.nasioc.com/forums/show...hreadid=477393
seriously... not a good idea to run CAI on WRX, STi should be okay (only for some well known brand.)
but you said you are going to get UTEC anyways, BUT UTEC won't take control until you press your gas panel more than 30%. so your stock ECU will still take control of your car MOST OF THE TIME. so your car will still run lean MOST OF THE TIME.
get a reflash which tuned for intake will be better for your need if you really wanna get a intake. but wut's the point?
kool168 is offline   Reply With Quote
Old 02-02-2005, 11:55 PM   #11
Woody
Member#: 15743
2002 Impreza TS
Blue Ridge Pearl
Sorry if this sounds like a complete newbie question, but why would a CAI be ok for a STI and not a WRX?
Woody
Woody is offline   Reply With Quote
Old 02-03-2005, 12:42 AM   #12
kool168
Member#: 61006
Woody
STi runs pig rich from stock, (that's why all STi shoot big flames out when they run catless TBE) where WRX runs rich, but not that RICH.
Old 02-03-2005, 01:58 AM   #13
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
I'm running straight 4" pipe into the fender and I've just got some patches to keep the intake from sucking in too much hot engine air. I put a bit of a twist on the usual snorkus removal, and I took out the black plastic under-hood scoop thing that directs air(and water) into the fender.
I could be wrong, but lately when I'm really going for it the car seems to be 'mushy' at peak output, almost like it's running rich or something.
So I was thinking I should try to add the scoop back in but I want to avoid having it installed on a rainy day.. Argh!
420WRX is offline   Reply With Quote
Old 02-03-2005, 02:23 AM   #14
tora
Member#: 5851
09 Forester XT
+ NA Miata
You really don't need to worry about rain. it will not cause your engine to hyrdo lock. Unless you hit a huge puddle and suck a mass of water into the engine, you are free and clear.
Old 02-03-2005, 02:45 AM   #15
Ken
Member#: 34
2005 WRX STi
World Rally Blue
Tora will pee on it if you don't watch out. That's what he means.
Ken is offline   Reply With Quote
Old 02-03-2005, 10:27 AM   #16
420WRX
Member#: 27752
Yeah? I guess if rally guys intentionally inject water, the occasional dose of rain water can't be so bad?
Old 02-03-2005, 11:20 AM   #17
tora
Member#: 5851
09 Forester XT
+ NA Miata
Think of it this way....a lot of smaller planes (Cessna and others) will use subaru flat fours as their engines. These are locomacated right in the front and have basically direct air intake from right in front. These planes fly at reasonably high speeds (in comparison to our cars) and rain goes right into the filter and then into the engine. But with that amount of water the rain turns to mist and is all but gone by the time it get's past the throttle body, it does no damage to the engine. You really have to submerse it with a WASH of water before damage will result. That being said, a CAI that goes right to the bottom of the fender well, or "close" to the road is not a good idea in places that have lots of big puddles....if you hit a puddle and submerse the filter, or even rocket a big splash into it driving through a large puddle you will be prone to hydro-lock.
Old 02-03-2005, 11:40 AM   #18
kwilson36
Member#: 67449
03 VF22, TXS FMIC
EcuTek, Catless...:)
Got me a AEM CAI ... never had a problem. Running stage 4 - the FMIC with EcuTek all tuned up. I deffinetly notice a difference when the cooler weather comes around.... then again the IC like the cooler air... I'll be going to short ram when i get my FM..
This arguement has been done to death. My oppinion... dont waste the money do the silencer delete and a drop in K&N and spend the money on Samco IC hoses and a bigger scoop to get more air flow across the IC..
-K
kwilson36 is offline   Reply With Quote
Old 02-03-2005, 12:06 PM   #19
steve
Member#: 4718
~ too
many to list
Does anyone have a stock airbox for sale?
pm me if so.
steve is offline   Reply With Quote
Old 02-03-2005, 12:11 PM   #20
kool168
Member#: 61006
i assume those subaru techician who designed our cars are much smarter than most of us. so "the black plastic under-hood scoop thing that directs air" shouldn't direct water... even if it does direct the water in there and it won't do any harm to our cars. there must be a purpose for that thing under the hood otherwise they wouldn't put it there.
Old 02-03-2005, 02:16 PM   #21
Happy_Days
Member#: 35049
2011 Mercedes C63
OE Tune 538/500
Here we go again =)
W/o tuning, neither the STI nor the WRX will benefit (consistently) from using a CAI or Shortram.
With the shortram, you get a really nice BOV sound, but -- Incorrect MAF readings can cause problems.
Happy_Days is offline   Reply With Quote
Old 02-03-2005, 05:14 PM   #22
kool168
Member#: 61006
Originally Posted by Happy_Days
Here we go again =)
there are MANY intakes in the market won't affect MAF readings...
such as:
http://www.knfilterchargers.com/sear...rod=69-8001TWR
http://www.turboxs.com/wrx/wrxintake.shtml
http://www.airpowersystems.com.au/wrx/my01/hfa.htm
ETC.
where tyhoon proves 12 hp gains
Old 02-03-2005, 06:15 PM   #23
Uncle Ben
Member#: 28628
2003 WRX Sedan
World Rally Blue Pearl
My Trust foam short ram intake never caused any problems when I ran it. I've had other short rams that really messed with the MAF readings, but not that one.
Uncle Ben is offline   Reply With Quote
Old 02-03-2005, 06:19 PM   #24
420WRX
Member#: 27752
Originally the scoop fit under the hood sucking in fresh air (and potentially rain/water) into the fender area where it would meet up with the silencer/snorkus that is designed to separate air and water. I don't have the snorkus installed anymore so I am worried that the water will follow the air path and get into the intake.
Old 02-03-2005, 09:54 PM   #25
rexilla
Member#: 41285
I've had a APS CAI on all my rex's.... Read up on them here >> http://www.airpowersystems.com.au/wrx/my01/hfa.htm
rexilla is offline   Reply With Quote
WRX CAI on my 07 2.5i Vizzionz Normally Aspirated Powertrain 18 01-14-2008 11:32 AM
Injen CAI for 05sti used on 06 wrx generalganja Newbies & FAQs 5 06-23-2007 04:38 PM
02-05 wrx cai on an 07 will it work? Ti_22 Newbies & FAQs 19 01-02-2007 03:35 PM
04 STi Fujita CAI on a 02 WRX 02WRXSTiImpreza Factory 2.0L Turbo Powertrain 3 11-22-2006 06:59 PM
Need help on COBB CAI on MY02 RS blackbok Normally Aspirated Powertrain 7 11-16-2002 01:33 AM
Message Board Statistics All times are GMT -4. The time now is 05:42 AM.
