Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 02-02-2005, 08:20 PM   #1
wgknestrick
Member#: 32576
04 STI
Default Hydra Users: Anyone know the Hydra injector mapping?
The Hydra can use 1-8 injectors and they are numbered accordingly. But the Hydra can only fire them consectively, IE 1,2,3,4, not 1,3,2,4.
So how do the Hydra injector #s map to the EJ cylinder #s?
I am trying to add a small % of fuel to my #4 cylinder.
wgknestrick is offline   Reply With Quote
Old 02-02-2005, 08:39 PM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
The injection trim for cylinder 4 is labeled with the appropriate cylinder.
If you want to add fuel to cylinder 4 then change "injection 4 trim."
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 02-02-2005, 08:50 PM   #3
jlee8196
Member#: 22211
I don't think you need to add more fuel to just one (#4cyc) and not the other.
Use the auto tune feature, the AFR map on it are concider very safe, which means all 4 cycle with run slightly richer. Which means you'll run even richer on #4cycl. by adding more fuel. If you want to aggressively tune it, it's more like how to subtract fuel on other three cycl.
jlee8196 is offline   Reply With Quote
Old 02-03-2005, 07:32 PM   #4
wgknestrick
Member#: 32576
04 STI
So is cylinder #2 mapped to injector #3?
Old 02-03-2005, 07:49 PM   #5
Element Tuning
Member#: 54918
673 WHP Element
Yes, so it's Inj 1 (cylinder 1), Inj 2(cylinder 3), Inj 3 (cylinder 2), and inj 4 (cylinder 4).
Thanks,
Phil
Old 02-03-2005, 09:41 PM   #6
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Hey, that's good info to know. That should be in a guide or something!
jblaine is offline   Reply With Quote
Old 02-04-2005, 11:52 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Old 02-04-2005, 12:59 PM   #8
MojoHand
Member#: 33130
This doesn't make a whole lot of sense. The autotune feature will assure that the combined AFR will hit the prescribed target. Raising one cylinder or dropping the other three should have the same effect (post autotune).
MojoHand is offline   Reply With Quote
Old 02-04-2005, 06:43 PM   #9
wgknestrick
Member#: 32576
04 STI
This is not a work around for total engine AFR, but a way to raise or lower a cylinder's AFR individually. I can be argued that cylinder #4, then cyl #2 run hotter, and leaner than 1 or 3. These are by far the most damage prone cylinders (not arguable), so (if you wanted) you could add a couple% more fuel to help give you a little bit of a safety net on those individual cylinders.
Check out this thread for some info and please note that this is not endorsed by Phil or Element Tuning. If you read throughout the thread, data is presented that show that this could be related to the header setup as EGTs were lower and more even with a GPmoto header.
http://forums.nasioc.com/forums/show...ht=channel+egt
Old 02-04-2005, 07:35 PM   #10
MojoHand
Member#: 33130
I wasn't suggesting that that it had anything to do with setting the total engine AFR; your intentions were obvious. I was simply pointing out to jlee that raising one or lowering three will result in the same end result, albeit with slightly different values in the base fuel map post autotune.
Old 02-05-2005, 10:16 AM   #11
Element Tuning
Member#: 54918
673 WHP Element
By all means put it in the guide, it's accurate after all
wgknestrick,
Just be careful with how much fuel you add to individual cylinders. I've experimented a little but to do this safely you will need to tap all 4 exhaust ports on the manifold and either move your one probe around while plugging the others, or use 4 separate probes. In all honestly probes can vary so you may just want to use one probe and move around the cylinders.
Keep boost moderate and try averaging 4 similar pulls per cylinder, with the same tank of gas, and it the same tuning area. Take note of your coolant and air temps during the runs to make sure they are as close as possible.
From most of the engines I've seen taken apart it's pretty apparent that 2 and 4 indeed either run leaner or hotter as thereís usually significantly less carbon build up.
Thanks,
Phil
Old 03-07-2005, 05:12 PM   #12
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Old 03-07-2005, 05:12 PM   #13
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Correct?
Anyone know if EVO injectors will work on wrx oxox55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-27-2009 11:43 AM
Anyone know the stock map sensor calibration numbers for UTEC? texas05sti Texas Impreza Club Forum -- TXIC 6 11-17-2007 12:33 PM
Anyone Know of Future Accessport Maps? Red Rexx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 12-22-2004 01:02 PM
Anyone know the size of the windshield wipers on the WRX? gary501 Interior & Exterior Modification 5 01-16-2002 11:51 AM
anyone know the the wiring gor the factory clock SWEETWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-07-2002 07:36 PM
