Welcome to the North American Subaru Impreza Owners Club Monday December 22, 2014
Old 02-02-2005, 10:08 PM   #1
e11ys
Member#: 77106
'02 Brodozer
'11 Outback 3.6R
Question Replacement gauge for stock pod...
I have a 02 WRX w/ the factory boost guage that is mounted on the steering column. It reads in MPa I think. Is there anywhere I can get a gauge that reads in PSi which will fit in the factory housing? I'm not sure the exact size, but all the ones I've seen where bigger than 2 inches, which I know is too big. Thanks.
Ellys
e11ys is offline   Reply With Quote
Old 02-02-2005, 10:11 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The factory gauge is 42mm. You can get one of the Omori 45mm gauges, that read in PSI, and mount it in the factory pod with a bit of "persuasion".
Old 02-02-2005, 10:13 PM   #3
e11ys
Member#: 77106
'02 Brodozer
'11 Outback 3.6R
Thanks, I'll look into that.
Ellys
WTT: Drivers side A-Pillar with gauge pod/gauges for stock xfactor58 NESIC Private Classifieds 4 03-29-2008 12:32 PM
Fitting 52mm gauges in stock pod paulmeisterpk Interior & Exterior Modification 5 03-21-2006 08:46 PM
Gauges for center pod that match STi dash gauges? ZenBoy Electrical & Lighting 4 08-02-2003 01:28 PM
Where to get mount plate for 52mm gauge for OEM pod? jmaiken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-28-2002 03:04 AM
52mm Defi Gauges in stock pod? no_rex_yet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-14-2002 02:15 PM
