#1 |
Member#: 49465
Vehicle:03 Bugeye Wagon Red |
hey guys..I got a 02 RS and I got a real bad problem.. I think my rear differential.. is shot..
I did a wrx engine conversion.. like a month.. ago.. it was running.. fine until... my differential start making whining noise.. I think its the differential bearing or something... it gets louder when I speed up more.. please can someone tell me what i should do.. do I need to get it rebuild?? what should I do?? can someone tell me what differential fit on my 02 RS and what is better and quick why to get rid of the noise and save money.. let me know.. I AM USING 02 RS TRANNY AND REAR DIFF.. SOMEONE TELL ME WHAT OTHER REAR DIFF FITS AND WORK ON MY CAR.. SO I COULD GET ONE..
#2 |
Member#: 1185
Vehicle:I flap my gums and now I'm a specialist |
Are you using a Wrx gearbox?
#3 |
Member#: 51282
Vehicle:98 RS black & blue from parking |
^^ If so, you'll want to consider a WRX rear diff.
#4 |
Member#: 33901
Vehicle:04 04 STI No AWD, Not interested |
You can use the RS tranny/diff. Upgrade the clutch(RS..I have Exedy) and swap the flywheels(the RS fits the WRX).
#5 |
Member#: 56061
RMIC
ver 7 swap is a GREAT option for you as you have an 02, another route would be to get different block and heads and just keep your intake manifold and wiring complete, for example you can get a ej20g block for relatively cheap.
#6 | |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
What does this have to do with the thread topic? Your answer has absolutely nothing to do with his problem......The problem is at the other end of the car...... Jay Storm |
#7 |
Member#: 26067
Vehicle:2003 WRX Open Sourced |
basically we need to know if all your tranny parts are from the same car.
#8 |
Member#: 3362
Vehicle:1985 I've wired a Few cars in my day |
Find out what the final drive is and then replace the diff with the correct one. IIRC the 02 RS came with an open diff once again but I'm not 100 percent sure on that. If that's the case and it's still 4.11 like the earlier RS' pick up a diff from an 00 or 01 RS and you'll be happy as a clam.
Z |
#9 |
Member#: 15322
SCIC
Vehicle:1995 gf wagon Blue Green Metallic 340 |
#10 |
Member#: 49465
hey... thanks for the nice chart.. just wondering.. since rear gear ratio is the same as 98-99 to 02-03 RS.. I could put 98-99 RS diff in my car??
also how bout 01 RS rear diff w/ LSD would it work on my 02 RS? let me know.. thanks |
#11 |
Member#: 3362
put one on that is a LSD you'll get better performance in the snow and the wet.
Z |
#12 |
Member#: 49465
can someone tell me if 01 RS rear diff W/LSD fits 02 RS without any problem??
without blowing my tranny..?? what do I need to change with it? axle?? let me know thanks.. |
#13 |
Member#: 15322
SCIC
The ratios appear fine, its the physical interface that you need to confirm. This would be the attachment of the axle half-shafts to the diff. (length; innie or outie) and the flange that attatches to the drive shaft. The flange should be fine but I mention it because STI diffs have a different flange bolt pattern, so there have been known mis-matches. If the axles don't fit you could check the rear axles from a WRX sedan to see if those work as substitutes.
Btw: have you drained the rear diff & looked inside w/ a flashlight? You may want to confirm that this is the problem before you go about doing repairs that may be costly, time consuming, and much ado about nothing. Check rear hub bearings and axles too as nudging a curb in the snow and the salt roads could take a toll. Those other components will whine proportionally w/ increased speed also. Last edited by tbd; 02-04-2005 at 03:34 AM. |
#14 |
Vendor
Member#: 75855
South East
Vehicle:04 Dynapack |
just double check the center diff ratio.
wrx front 1: 1.1 rear 3.90 front 3.54 rear rs 4.11? |
#15 |
Member#: 49465
I lift the car.. and roll the car on the lift.. and the noise was from the rear differential.. there was no play on the universal joint.. I checked the gear oil.. and it was dirty as Hell.. but I changed the oil like 10,000 miles ago.. so I figure the differential. was shot.. well my warranty company will pay for the diff. I just wanted to know few things.. before I order another diff.. since 00-01 came with LSD maybe I could try to fit it in.. so I could have better control in the snow and and rain.. if its too much hassle to change all that I rather stick with the 03 Rear diff.. well thank you for you help.. everyone..
#16 |
Member#: 3362
Did you by any chance check your wheel bearings? It could be a wheel bearing.
#17 |
Member#: 15322
SCIC
an earlier model diff will be less costly if your coverage allows you to pick up used. Axles will need to be checked to see if they fit.
Of course, if the noise turns out to be a bearing in the hub, replacing the bearing would be much cheaper. Maybe you could try flushing out the rear diff w/ gear oil first. Drain, Jack up the rear, overfill the diff, plug, drive around, drain. (cheap) The noise should change if its coming from the rear diff. |
| Thread Tools | |
| Display Modes | |
| I think my rear differential is done... Anyone have one? | tabrad | Rocky Mountains Impreza Club Forum -- RMIC | 15 | 05-21-2008 11:26 PM |
| How can I tell if my rear diff is shot. | rs6er | Transmission (AT/MT) & Driveline | 1 | 12-01-2006 04:01 PM |
| My rear differential is starting to tick me off | Lachlan | Transmission (AT/MT) & Driveline | 4 | 06-17-2006 06:32 PM |
| I think my rear dif is going out but... | WRX-U | Transmission (AT/MT) & Driveline | 9 | 02-05-2004 02:29 PM |
| I think my CV joint is shot. | Kwyjibo | Transmission (AT/MT) & Driveline | 5 | 01-21-2004 04:49 PM |
