Old 02-03-2005, 08:09 AM   #1
sepulchral
Member#: 80807
Default Speedo not working
My speedometer doesnt work, and the check engine light is on due to it. Last night i felt the car bogging some like it was dying down and Everytime i start the car it flashes "AT OIL TEMP" this car runs perfect before the speedometer stopped working, can anything bad happen? Thank you.
sepulchral is offline   Reply With Quote
Old 02-03-2005, 03:36 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
How do you know that the CEL is on due to the speedometer? If you pulled the code, what is the code? If you didn't, go pull the code and post that. It would also help if you posted the make (Subaru?), model & year car you are talking about.
AT Oil Temp means the auto transmission fluid (oil) is getting too hot -- either a problem with cooling it, or a problem with the transmission, generating excess heat.
Old 02-03-2005, 04:04 PM   #3
anders8
Member#: 26658
1 Love Grassroots
NASA Rally Sport FTW!
If your speedo isn't working, your Omputer won't know how fast your car is going... it thinks you're parked. So, it won't put the engine under load over 4k rpm or so.
Plus, it would really help if we knew what kind of car it was.
Go get your speedo fixed.
Anders
anders8 is offline   Reply With Quote
Old 02-04-2005, 05:07 PM   #4
sepulchral
Member#: 80807
subaru legacy outback 1997 2.5l motor 89k miles
speedo not working subydriver95 Transmission (AT/MT) & Driveline 7 02-14-2006 06:27 PM
Causes of speedo not working? Scooby-Doode Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-13-2005 10:17 PM
Speedo not working (mech--> elect) cindergarden Subaru Conversions 1 09-11-2005 10:07 PM
Speedo not working, car in limp home mode trhoppe South East Region Forum 10 02-04-2004 02:24 PM
Speedo not working, car in limp home mode trhoppe Transmission (AT/MT) & Driveline 1 02-04-2004 01:11 PM
