Old 02-03-2005, 02:59 PM   #1
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Default 85 GL 10 ported heads / High egt's
Just had a guy come in and said that he had his heads pocket ported? Mild port. Now his egt are to high. Would a walbro fuel pump and an Apexi Super AFC II do the trick. I have no idea what size of injectors are on the 85, 1.8, GL. Turbo is pretty small and no intercooler.
I thought putting toluene 10 gals to 12 would slow his burn rate and lower egt's.
I am building and 02 wrx to 320+ whp, but not much knowledge for Harry's 85 GL, and his egt problems.
Thanks
Dave
unkadave is offline   Reply With Quote
Old 02-03-2005, 09:35 PM   #2
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
????? Is this the right forum
Old 02-03-2005, 10:31 PM   #3
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
High EGT can be cause by retarded timing also. He needs to measure the air/fuel ratio and then go from there. How high were the egts?
Scoobie Steve is offline   Reply With Quote
Old 02-04-2005, 08:37 AM   #4
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
He does not have a gauge. Did a rebuild and the "turbo side pistons were cooked". It almost sounded hike a ambient ?? temp problem. But he says going up hills causes a heat problem. Which is a classic A/F ratio indicator. He is pretty low tech, and we do not have and A/F setup.
thx
Old 02-04-2005, 10:30 AM   #5
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
There are so many causes of temp troubles on these cars.
Cooked pistons, in my experience is likely the result of a lean condition(its common for #3 to go lean at high boost because of the crappy fuel rail design), but it could also be a predetonation problem caused by timing, carbon build up, slag from a crappy porting job.
Need to supply much more empirical evidence.
At this point, if you suspect high EGTs, you need to find a way to actually measure them.
Given that cooling problems are normal for a subaru of this age and based on my experience with them, I would start with the cooling system, unless you have evidence that its only one side thats not functioning properly. While heating up while going up hills may be a classic A/F indicator, on these cars its also a classic cooling system indicator
Calebz is offline   Reply With Quote
Old 02-04-2005, 04:05 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Is he running a boost controller? Overboosting those teeny little turbos will also cause high EGT's...
Old 02-04-2005, 06:41 PM   #7
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
No boost controler. Just the ported heads. Does anybody think 2 gals of toluene per tank would help?? I run toluene in my built wrx and it brings down the EGT's. Nobody I know has tuning for an 85 (ecu reflash). I think he just needs more fuel - with the ported heads, but I'm not sure and don't know what would be the right solution.
gl-10 head gasket nickgt5.0 'Old School' Subaru Forum 3 03-31-2008 02:48 AM
87 GL-10, five lug, head work desperate 'Old School' Subaru Forum 0 06-30-2007 04:16 PM
85 GL-10 Radiator Fan Troubles yoyeti 'Old School' Subaru Forum 3 12-14-2006 02:02 PM
85 GL 10 ported heads / high egt's unkadave 'Old School' Subaru Forum 0 02-03-2005 09:39 PM
I need a 85-89 GL,GL-10,or RX Sub_Speed_Guy Rocky Mountains Impreza Club Forum -- RMIC 0 09-04-2003 08:31 PM
