Old 02-03-2005, 04:30 PM   #1
tbd
Member#: 15322
1995 gf wagon
Blue Green Metallic 340
Default Disassembling seized suspension parts.
Howdy all, thought I'd ask for someone else's two cents on what they'd do in this situation. This isn't urgent, just something I'm dreading & need to plan for in the future.
During a rear drum to disc conversion in the past I found that the bolt which holds the rear control arms to bottom of the rear knuckle to be seized on one corner. (bolt end) I was still able to remove the knuckle & do the conversion but I know I'll need to face that bolt sooner or later.
Pounding on it w/ a deadblow hammer only distorted the nut end w/ the threads. WD-40 didn't seem to loosen it in the short span of time I wanted it done in. (eg: wanted it done yesterday) And I could'nt sqeeze a pry bar between the bolt head & the bushing. It seems that the steel insert & the bolt are seized.
So knowing that I'll have to free that end when I install uprated bushings into the control arms, how would you approach removing this?
I've only heard of torch & PB blaster so far. Any special tools that might help? None of my pullers seem to be relevant to this job.
I would have asked in the maintenance forums but I figure swappers over here were more likely to have run into this problem already.
Thanks,
tbd is offline   Reply With Quote
Old 02-03-2005, 06:23 PM   #2
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
PB blaster and air tools! Using those two things I never have a problem.
When you reasemble try anti-seize, works great.
wrx plus is offline   Reply With Quote
Old 02-03-2005, 06:48 PM   #3
tbd
Member#: 15322
1995 gf wagon
Air tools would'nt make a difference in this case as the bolt has no threads to latch onto to press itself out. Both the nut & bolt are free & not captive. Turning the bolt simply spins the rubber suspension bushing in its outer sleeve. What is seized is the bushing insert & the pivoting portion of the suspension bolt. These are usually supposed to be lubed, but I guess this car saw too many winters. The bolt & the bushing are what I want to separate so that I may press out the bushing for replacement. The bolt could be pressed out w/ the bushing but you'd still have to remove the stuck part in order to install. Just wondering if there are any creative ideas. I have'nt come up w/ any yet.
BTW: I use power tools to disassemble it already. This snag is just something the the tools have'nt helped solve.
http://community.webshots.com/photo/...57428954AzlrZA
Part 24 and the bolt are stuck together.
Old 02-03-2005, 09:06 PM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I've seen this before on a WRX. Take the lateral link off with the bolt seized to it. Cut off the bolt. Press out the bushing and what's left of the bolt. Replace bushing, buy a new bolt. You can also try to just press out the bolt, but good luck with that. I did manage to press out a seized one on a trailing arm with about 25 tons of pressure.
Option 2 is to buy a new bolt and just get a new lateral link, they are cheap.
Old 02-03-2005, 10:22 PM   #5
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Cut the bolt head off and pound it out. Replace the lateral links with some nice Whiteline adjustable ones.
Z
Zephyr is offline   Reply With Quote
Old 02-03-2005, 11:43 PM   #6
JDM_Scobaru
Member#: 57809
yah i had this problem and i had to get new everything, like DWX said its nice to have new stuff and doesnt cost that much.
JDM_Scobaru is offline   Reply With Quote
Old 02-03-2005, 11:48 PM   #7
tbd
Member#: 15322
1995 gf wagon
Thanks guys,
That sucks, I had hoped to salvaged some of the parts too. I have some spares but not enough to do this w/o scrounging a bit.
Thanks again.
Old 02-04-2005, 06:10 PM   #8
uberbrighton
Member#: 56676
1996 Impreza
"Brighton" Hunter Green
Hey Tony... I've still got alot of my parts, if you need something PM me.
uber
uberbrighton is offline   Reply With Quote
WTB: Stock GC suspension, or suspension parts. AcquaCow MAIC Private Classifieds 3 09-13-2007 09:42 AM
A/C parts, Suspension parts and more from a L NinosAutoAccesories Private 'For Sale' Classifieds 12 07-18-2006 05:12 PM
SPT suspension parts VS STI suspension parts coil222 Brakes, Steering & Suspension 1 07-15-2006 05:24 AM
WTB: WRB Body parts & Suspension Parts jimbo1972 Private 'Wanted' Classifieds 4 07-04-2004 02:19 PM
FS: Stock Suspension Parts & Stock Parts DoDO Brown Private 'For Sale' Classifieds 3 12-13-2003 02:38 PM
