Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Old 02-03-2005, 12:22 AM   #1
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
Default I think my rear differential is shot
hey guys..I got a 02 RS and I got a real bad problem.. I think my rear differential.. is shot..
I did a wrx engine conversion.. like a month.. ago.. it was running.. fine until... my differential start making whining noise.. I think its the differential bearing or something... it gets louder when I speed up more.. please can someone tell me what i should do.. do I need to get it rebuild?? what should I do?? can someone tell me what differential fit on my 02 RS and what is better and quick why to get rid of the noise and save money.. let me know..
I AM USING 02 RS TRANNY AND REAR DIFF.. SOMEONE TELL ME WHAT OTHER REAR DIFF FITS AND WORK ON MY CAR.. SO I COULD GET ONE..
taeyax82 is offline   Reply With Quote
Old 02-03-2005, 01:05 AM   #2
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Are you using a Wrx gearbox?
Ver.III is offline   Reply With Quote
Old 02-03-2005, 01:52 AM   #3
jamesfacts
Member#: 51282
98 RS
black & blue from parking
^^ If so, you'll want to consider a WRX rear diff.
jamesfacts is offline   Reply With Quote
Old 02-03-2005, 02:02 AM   #4
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Impreza GC8
You can use the RS tranny/diff. Upgrade the clutch(RS..I have Exedy) and swap the flywheels(the RS fits the WRX).
joubtt is offline   Reply With Quote
Old 02-03-2005, 02:18 AM   #5
phunkeeHomosapien
Member#: 56061
ver 7 swap is a GREAT option for you as you have an 02, another route would be to get different block and heads and just keep your intake manifold and wiring complete, for example you can get a ej20g block for relatively cheap.
phunkeeHomosapien is offline   Reply With Quote
Old 02-03-2005, 02:46 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
I remember this one time my dad asked a mechanic at Sears ('twas convenient) to check the lube in the "pumpkin". This mechanic started to pop the hood and I thought my dad was gonna break his fingers.......
What does this have to do with the thread topic? Your answer has absolutely nothing to do with his problem......The problem is at the other end of the car......
Jay Storm
Old 02-03-2005, 03:52 AM   #7
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
basically we need to know if all your tranny parts are from the same car.
HeMan1320 is offline   Reply With Quote
Old 02-03-2005, 12:25 PM   #8
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Find out what the final drive is and then replace the diff with the correct one. IIRC the 02 RS came with an open diff once again but I'm not 100 percent sure on that. If that's the case and it's still 4.11 like the earlier RS' pick up a diff from an 00 or 01 RS and you'll be happy as a clam.
Z
Zephyr is offline   Reply With Quote
Old 02-03-2005, 12:42 PM   #9
tbd
Member#: 15322
1995 gf wagon
Blue Green Metallic 340
tbd is offline   Reply With Quote
Old 02-03-2005, 11:08 PM   #10
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
hey... thanks for the nice chart.. just wondering.. since rear gear ratio is the same as 98-99 to 02-03 RS.. I could put 98-99 RS diff in my car??
also how bout 01 RS rear diff w/ LSD would it work on my 02 RS? let me know.. thanks
Old 02-03-2005, 11:19 PM   #11
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
put one on that is a LSD you'll get better performance in the snow and the wet.
Z
Old 02-04-2005, 02:41 AM   #12
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
can someone tell me if 01 RS rear diff W/LSD fits 02 RS without any problem??
without blowing my tranny..?? what do I need to change with it? axle?? let me know thanks..
Old 02-04-2005, 04:25 AM   #13
tbd
Member#: 15322
1995 gf wagon
The ratios appear fine, its the physical interface that you need to confirm. This would be the attachment of the axle half-shafts to the diff. (length; innie or outie) and the flange that attatches to the drive shaft. The flange should be fine but I mention it because STI diffs have a different flange bolt pattern, so there have been known mis-matches. If the axles don't fit you could check the rear axles from a WRX sedan to see if those work as substitutes.
Btw: have you drained the rear diff & looked inside w/ a flashlight? You may want to confirm that this is the problem before you go about doing repairs that may be costly, time consuming, and much ado about nothing.
Check rear hub bearings and axles too as nudging a curb in the snow and the salt roads could take a toll. Those other components will whine proportionally w/ increased speed also.
Old 02-04-2005, 12:05 PM   #14
Performance Driven
Vendor
Member#: 75855
04 Dynapack
just double check the center diff ratio.
wrx front 1: 1.1 rear
3.90 front 3.54 rear
rs
4.11?
Performance Driven is offline   Reply With Quote
Old 02-04-2005, 10:13 PM   #15
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
I lift the car.. and roll the car on the lift.. and the noise was from the rear differential.. there was no play on the universal joint.. I checked the gear oil.. and it was dirty as Hell.. but I changed the oil like 10,000 miles ago.. so I figure the differential. was shot.. well my warranty company will pay for the diff. I just wanted to know few things.. before I order another diff.. since 00-01 came with LSD maybe I could try to fit it in.. so I could have better control in the snow and and rain.. if its too much hassle to change all that I rather stick with the 03 Rear diff.. well thank you for you help.. everyone..
Old 02-04-2005, 11:07 PM   #16
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Did you by any chance check your wheel bearings? It could be a wheel bearing.
Old 02-04-2005, 11:40 PM   #17
tbd
Member#: 15322
1995 gf wagon
an earlier model diff will be less costly if your coverage allows you to pick up used. Axles will need to be checked to see if they fit.
Of course, if the noise turns out to be a bearing in the hub, replacing the bearing would be much cheaper.
Maybe you could try flushing out the rear diff w/ gear oil first. Drain, Jack up the rear, overfill the diff, plug, drive around, drain. (cheap) The noise should change if its coming from the rear diff.
I think my rear differential is done... Anyone have one? tabrad Rocky Mountains Impreza Club Forum -- RMIC 15 05-22-2008 12:26 AM
How can I tell if my rear diff is shot. rs6er Transmission (AT/MT) & Driveline 1 12-01-2006 05:01 PM
My rear differential is starting to tick me off Lachlan Transmission (AT/MT) & Driveline 4 06-17-2006 07:32 PM
I think my rear dif is going out but... WRX-U Transmission (AT/MT) & Driveline 9 02-05-2004 03:29 PM
I think my CV joint is shot. Kwyjibo Transmission (AT/MT) & Driveline 5 01-21-2004 05:49 PM
