Old 02-05-2005, 05:46 PM   #1
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
Default Best way to plug port
I am looking for the best way to plug the second crankcase vent on a USDM Sti block, I did a search but no info on how to or what to use. Please help.
CUNNINGHAM is offline   Reply With Quote
Old 02-05-2005, 10:14 PM   #2
SJwrx
Member#: 14970
1997 GF8
multi
large silicon cap?
Rich
SJwrx is offline   Reply With Quote
Old 02-06-2005, 10:28 AM   #3
mykrrrr
Member#: 733
'13 Focus ST
First I vented both into the intake trac then decided that it needed to be plugged. I cut a bit of hose and stuck a big bolt in it and then used a band clamp on it. It's been ok since the rebuild so I guess it's working.
Ghetto fix but it works.
-mykr.
mykrrrr is offline   Reply With Quote
Old 02-06-2005, 11:56 AM   #4
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
I can't plug it I have to remove it because it hits the cross over pipe slightly. Any suggestions?
I have a 1998 DOHC
Old 02-06-2005, 03:09 PM   #5
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
thought the crankcase needed that pressure to be relieved?
HeMan1320 is offline   Reply With Quote
Old 02-06-2005, 03:45 PM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
It may be too late now, but you probably coulda pulled the hose barb out and then tapped it for an AN_ sized plug.
Can you source an STi crossover tube that will clear the vent?
Jay Storm
Old 02-06-2005, 06:47 PM   #7
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Pull the tube out and press in an aluminum plug with a lip.
Ver.III is offline   Reply With Quote
Old 02-06-2005, 06:56 PM   #8
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
or you could go ghetto fix and cut it off, and fill it with JB Weld, that stuff's the ****.
Hurley 2.5 WRS is offline   Reply With Quote
Old 02-06-2005, 07:20 PM   #9
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
Ver.III Pull the tube out and press in an aluminum plug with a lip.
Any idea where to get such a plug.
What does Rallispec do?
Old 02-06-2005, 07:32 PM   #10
Ver.III
Member#: 1185
I flap my gums
We had one machined one out. The lip is there just incase that the press fit is too small and it does not fall in. Any local machine shop should be able to cut you one in a few minutes. Just show them the vent tube that you pulled out of the block.
Old 02-06-2005, 08:38 PM   #11
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
We should find someone who could make these on a regular basis, I am sure there would be some sales.
Best way to plug trunk holes?? eastcoastGC8G Mid Atlantic Impreza Club -- MAIC 6 03-21-2010 11:22 PM
What Is the BEST WAY to Change Spark Plugs?? george3 Service & Maintenance 17 10-31-2009 10:11 PM
Best Way to Splice To Add Length to 8 gauge Amp Power Wire This Is Not Mike Car Audio, Video & Security 20 07-13-2008 09:52 AM
Is there a way to plug headphones to a PS2? Undepelo Off-Topic 11 09-15-2005 05:21 PM
Best way to get to Myrtle Beach SC IMPREZIV Tri-State Area Forum 13 06-17-2002 08:14 PM
