Old 02-03-2005, 10:20 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default What type of oil to use on high mileage car?
My beater is 92 Honda Prelude with over 150k miles on. I have 3 types of oil I have in mind of using.
1. Valvoline maxlife for engines with over 75k miles
2. Mobil1 synthetic oil
3. Conventional oil
What type of oil should I use on this car to prolong the life of an engine?
Thanks!
Old 02-03-2005, 11:22 PM   #2
Bottom Feeder
Member#: 2808
Keep putting in whatever has allowed it to last this long. If it hasn't had synthetic up until this point, don't start now, or you may start getting some small leaks. That Maxlife sounds like marketing and nothing else, but I'm sure it's good oil regardless.
Bottom Feeder is offline   Reply With Quote
Old 02-04-2005, 12:30 AM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
If your oil pressure is ok then keep doing what your doing.
Tim Sanderson is offline   Reply With Quote
Old 02-04-2005, 07:33 AM   #4
pezman04wrx
Member#: 66558
^^^ I'll second that one ... However if your oil pressure seems to run a bit low, you could always bump it up a level ... 5w-30 to 10w-30 ... Have to agree with staying with whatever brand you've always used though, lots of oils are different ... Different detergent levels, additives and so on ... It's always been my practice to stay with one brand (Mobil1) ... Don't really know if it matters, it probably doesn't, but it's less for me to worry about ...
pezman04wrx is offline   Reply With Quote
Old 02-04-2005, 10:26 AM   #5
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Are you burning/using oil? If not, don't do anything different. If you are, try a thicker grade.
OneOBS is offline   Reply With Quote
Old 02-04-2005, 11:01 AM   #6
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Like they said, whatever you've been using before should be fine. But as long as you don't have to pay too much extra, one of those "high mileage" oils could be handy too.
What Type of Sealent To Use for Headlights? (specific Brand?) WoopWoopSti Interior & Exterior Modification 10 08-14-2007 03:40 AM
Quick n00bie maintenance Q: What kind of oil to use? Stroke Off-Topic 19 10-11-2005 03:34 PM
Anybody know what type of Turbo is used in the WRC car? mrubino83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 08-23-2004 04:17 AM
What kind of oil to use? Impreza94L Service & Maintenance 2 12-09-2002 08:00 PM
What brand of oil to use in RS? Vigorous Newbies & FAQs 3 12-08-2001 04:03 AM
