Old 02-03-2005, 10:32 PM   #1
BruceC
Member#: 4962
2002 WRX Wagon
Sedona Red Pearl
Question Stumbling/hesitating on acceleration
Before I bring my '02 WRX to the shop, anything simple and cheap I can look at/replace to try to fix the problem? (i.e., spark plug wires, EGR valves, fuel filter, stuff like that).
Problem occurs regardless of how aggressive the acceleration or in what gear. Seems to get worse as engine warms up.
BTW, I just read the fuel filter thread (a likely suspect) -- but, dumb question, where's the filter located?
I have 36K miles on it.
I don't have an OBD2 scanner but maybe I should get one.
Geez, been awhile since I've been here!
BruceC is offline   Reply With Quote
Old 02-04-2005, 10:27 AM   #2
OneOBS
Member#: 63076
2004 Outback Sport
Red!
It could be a bad tank of gas, too.
OneOBS is offline   Reply With Quote
Old 02-04-2005, 11:55 AM   #3
BruceC
Member#: 4962
2002 WRX Wagon
Sedona Red Pearl
Considered that, and I might run this tank dry to see if it persists after the next fill-up. But it occurred briefly once before about two weeks ago (only lasted a day, and that was a few of tanks of gas ago) and has now reappeared and persisted over several days, starting before the most recent fill-up.
The first time it happened I chalked it up to a wicked cold spell we were having, but now the weather is normal to slightly warmer than average.
Naturally, I'm only using premium. And I use various gas stations.
BTW, if I'm seeing the diagram on subaruparts.com right, the filter is on or near the gas tank? Doesn't look very accessable if so.
Old 02-04-2005, 12:54 PM   #4
soldmyboxster
Member#: 65520
If I had to guess, I'd say it was some kind of vacuum leak or low fuel pressure.
soldmyboxster is offline   Reply With Quote
Old 02-04-2005, 01:25 PM   #5
OneOBS
Member#: 63076
2004 Outback Sport
Red!
I had a lot of water in my OBS when I bought it. It took about four tanks of treated (dry gas or eq) to get it all out.
Old 02-04-2005, 01:39 PM   #6
BruceC
Member#: 4962
2002 WRX Wagon
Sedona Red Pearl
Vacuum leak...hmm...usually pretty easy to find and fix. Sounds reasonable too. Thanks! And stay tuned...
[EDIT]: Nope, couldn't find a vacuum leak.
Old 02-07-2005, 08:12 PM   #7
brenden3010
Member#: 79461
04 STi
Its turbo lag Seriously though, when my cars recirculation hose came off, it lagged horribly, and felt like stalling, and under boost, its like the boost came on more instantaniously than gradually... not the instant power feeling you want though.
brenden3010 is offline   Reply With Quote
Old 02-08-2005, 07:18 PM   #8
Hoss
Member#: 26055
02 WRX
see this thread
Hoss is offline   Reply With Quote
Old 02-08-2005, 10:59 PM   #9
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
what maintenance has been done to the car???
Robin2 is offline   Reply With Quote
Old 02-08-2005, 11:24 PM   #10
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Please provide more information....is the CEL on? How many miles are on the car? Does the hesitation go away after driving? Did you just replace your air filter? Other than oil changes, what else has been done to the car? Modifications?
RexyGirl is offline   Reply With Quote
hesitation on acceleration subschutjer Newbies & FAQs 19 10-09-2008 08:38 AM
Bog/Hesitation on acceleration from stop, 2005 RS w/ injen CAI kevinmwolf Normally Aspirated Powertrain 9 01-03-2008 01:27 AM
Hesitation on acceleration AphexDouble Service & Maintenance 7 01-29-2007 12:35 AM
Help! New Hesitation on Acceleration Evil Dr. Scoob Normally Aspirated Powertrain 3 01-15-2003 02:50 AM
Hesitation on acceleration SCOOBER Normally Aspirated Powertrain 14 12-16-2000 10:45 AM
