Old 02-03-2005, 10:36 PM   #1
smain38ehampton
Member#: 79420
00 2.5 rs
blue
Default wrx into gc8
im am going to put a 02 wrx engine into my 00 rs. i was wondering if the engine mounts line right up. and if there is any other modification i should think about. plus what size injectors should i upgrade too?
smain38ehampton is offline   Reply With Quote
Old 02-03-2005, 10:40 PM   #2
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
you need a wrx front engine crossmember or an old legacy turbo crossmember, and everything lines up. Im using stock RS motor mounts for my wrx engine. Use a wrx fuel pump or get a walbro if u dont want to upgrade it later on. use stock wrx fuel injectors untill u need bigger. You need to buy the wrx whole wiring harness and merge the wrx/rs harness to wire it up.
ImprezaRSfan! is offline   Reply With Quote
Old 02-03-2005, 10:46 PM   #3
smain38ehampton
Member#: 79420
00 2.5 rs
blue
yea i have some one wiring the car for me who has done them before? what would u pay some one to do that? and what size turbo should i upgrade too?
Old 02-03-2005, 11:38 PM   #4
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Impreza GC8
www.i-speedusa.com
www.garagetuning.com
Check the 1st for most info, 2nd for basic info.
joubtt is offline   Reply With Quote
Old 02-04-2005, 12:26 AM   #5
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
http://forums.nasioc.com/forums/showthread.php?t=515550
this thread should be what ur looking for
snowman4us is offline   Reply With Quote
Old 02-05-2005, 02:39 PM   #6
Boxologist
Member#: 21118
fargin' n00bs.
Boxologist is offline   Reply With Quote
Old 02-05-2005, 02:56 PM   #7
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
damn those noobs hahah
all subaru engine bays are pretty close to the other there isn't anything MAJORLY different compared to honda's were the accord engine bay is pretty different from the civic or so on and so forth so if u want to throw an XT motor in your impreza or a Legacy motor in your baja for whatever reason it all bolts up.
scobaru is offline   Reply With Quote
Old 02-05-2005, 02:59 PM   #8
Takashi
Member#: 2536
2012 STi Hatch
not to mention the wiring... this is NOT any easy swap, like putting a b16 into a civic or something.
Takashi is offline   Reply With Quote
Old 02-05-2005, 03:31 PM   #9
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You would ONLY need this to clear the uppipe only, am I right?
FuJi K is offline   Reply With Quote
Old 02-05-2005, 05:23 PM   #10
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
yes, you would only need the crossmember to use the stock wrx manifold/uppipe setup, which most use
Ben
Old 02-06-2005, 10:35 AM   #11
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
The physical swap is the easy part. The wiring is the PITA but obviously it's been done hundreds of times.
Check the other swap threads as to what else you'll need.
-mykr.
mykrrrr is offline   Reply With Quote
Old 02-07-2005, 10:32 AM   #12
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
for a 99 impreza L you wouldnt need to replace axles would you?
99subi is offline   Reply With Quote
Old 02-07-2005, 01:13 PM   #13
Mumbles
Member#: 248
Nope, not the front ones.
Mumbles is offline   Reply With Quote
Old 02-07-2005, 02:51 PM   #14
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
how bout the rears?
Old 02-07-2005, 03:16 PM   #15
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
nope
and for that matter you don't need to change the transmission
Old 02-07-2005, 06:57 PM   #16
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
Impreza GC8
sweet thanks for the info
Old 02-07-2005, 07:04 PM   #17
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
i am still using the L tranny with my hybrid 257 =x
scoobyimpreza is offline   Reply With Quote
Old 02-08-2005, 09:20 PM   #18
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
Are the L tranny ratios good with rex swap
Old 02-09-2005, 01:58 AM   #19
subi_2.5rs
Member#: 67538
2003 impreza wrx
black/blue/purple
subi_2.5rs is offline   Reply With Quote
Old 02-09-2005, 01:59 AM   #20
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The MY99 L ratios are the same as the RS but with a 3.9 final drive. They'll be a little better because they're shorter. They'll feel like a non-RA tranny. Not that I've driven RA and non-RA but playing with gear ratios in GT3 does help out a lot. It'll be a little quicker with the RS tranny because of the 4.111 FD.
Old 02-09-2005, 11:07 AM   #21
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
no no nononononon
stop making gt3 references your embarasing yourself
its 90% about the final drive
Old 02-09-2005, 12:28 PM   #22
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I only use GT3 to watch where the RPM drops verses speed. and if you don't think that's accurate...then I have nothing more to say. I've stuck on 2.5RS ratios, L ratios, USDM STi ratios.... the rpm drops to where it would in the real cars I've ridden in. It IS the best simulator that I've use to watch where the rpm drops via going through gears.
ANYWAY!
People who've done swaps using the RS tranny like it more than say the USDM WRX tranny. The gearing is shorter than the WRX gear and ALSO the final drive is 4.111 making it good for street and track. I wouldn't want the RS gears though if I was track racing the car because it's not short enough. I would perfer the RA gears with 4.444 final drive, IMO.
The final drive is only 50% only IMO. Because gearing helps aid acceleration. If you have really sucky gear ratios, a final drive wouldn't help much.
Old 02-12-2005, 12:18 AM   #23
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
I've done the swap.. on my 02 RS.. its really worth it.. but its better just getting a WRX alot of work real PITA.. 00 RS is really worth it.. well got questions let me know.. few things i'm not sure of.. fuel pump controller.. don't know anything yet.. it will throw a CEL without the fuel pump controller.. you have to wire it up manually.. other things i could try to help you guys.. I did the wiring I did all the work.. It took me a month and half.. to get everything right and perfectly.. running.. later.. ( if anyone know anything about fuel pump controller.. let me know.. I want to get rid of the CEL.. thanks..
taeyax82 is offline   Reply With Quote
what i need to swap wrx into gc8? ILwrx Subaru Conversions 8 11-02-2005 05:46 AM
Experiences with USDM WRX engine into GC8? danc Normally Aspirated with bolt-on Forced Induction Powertrain 45 07-23-2002 04:20 PM
USDM wrx swap+ AEM EMS into GC8 best option? FLUBYUx2 Normally Aspirated with bolt-on Forced Induction Powertrain 38 06-28-2002 09:54 AM
WRX motor swap into GC8 ImpreziveRS Normally Aspirated with bolt-on Forced Induction Powertrain 27 05-13-2002 05:56 PM
WRX steering wheel into GC8 MixeD_MenacE Interior & Exterior Modification 9 04-29-2002 04:04 AM
