Vancouver Impreza Club
Old 02-03-2005, 11:06 PM   #1
march
Member#: 72169
04 WRX
Default Licence Plate Problemo
I got a problem about license plate, hope you all cool Imprezers can help me out.
My rear license plate for some reason keeps moving back and forth or in order words, it is not in place. From my inspection, I think that the screws holding the plate to the car is too long for the holes drilled into the car.
Qs
1) Am I heading the right direction on solving the problem?
2) Isn't stock screws perfect fit? If it is the screws' problem, where can I get new screws?
3) Can it be possibly the holes in the car's problem?
Thanks for looking . . .
march is offline   Reply With Quote
Old 02-03-2005, 11:07 PM   #2
Wycked
Member#: 68269
2004 WRX
Do you have a license plate frame for the plate? I remember when I put the plate on without the frame it wouldnt hold in place and the screws seemed too long, needed a thick frame.. just an idea, you prob have one
Wycked is offline   Reply With Quote
Old 02-03-2005, 11:10 PM   #3
march
Member#: 72169
04 WRX
Hey thanks for replying lightning fast..! I used to have a license plate frame, however, I removed it.
So are you saying that you have the same problem without a frame away? I found the front plate has no problem without a frame.
Old 02-03-2005, 11:49 PM   #4
polaris
Member#: 66663
2011 VW GTI
maybe '15 STI?
The screws you have are probably made to use with a frame. I dont have a frame and the screws are maybe 1 cm in lengh from what I remember.
polaris is offline   Reply With Quote
Old 02-04-2005, 01:22 AM   #5
lummer shawn
Member#: 71484
02 2.5 RS
BRP
if you dont want a frame on there, take the plate off, put in a couple washers between he plate and your car and put the screws back in. issue solved
lummer shawn is offline   Reply With Quote
Old 02-04-2005, 03:23 AM   #6
march
Member#: 72169
04 WRX
Woohoo. thanks a lot. but why by can I get this specific of washer? Just as big as I need right? But wouldn't a washer scratch the body paint?
Old 02-04-2005, 04:30 AM   #7
polaris
Member#: 66663
2011 VW GTI
maybe '15 STI?
you can use rubber washers probably or use metal ones on the outside of the plate.
Old 02-04-2005, 04:49 AM   #8
GlobalWaste
Member#: 74792
exactly what I was thinking ^
GlobalWaste is offline   Reply With Quote
Old 02-04-2005, 11:35 AM   #9
lummer shawn
Member#: 71484
02 2.5 RS
BRP
yeah, well i dont think you would want to use metals ones on the outside cuz it would look tacky. But you can find rubber ones at crappy tire or home depot or pretty much anywhere. The other thing is, usually where the screws go in to hold the license plate is a piece of plastic slight raised above the paint of the car anyways, and its behind the plate, but either rubber or metal would work. Actually, you can probably find plastic ones as well.
so check
crappy tire
home depot
wal-mart
or any other store like that - they should only be a 1$ or 2$ for a package of more than enough.
Old 02-04-2005, 09:54 PM   #10
march
Member#: 72169
04 WRX
100 thank yous guys !!
Really appreciate the helps.
Got pulled over for licence plate covers :( Eric Gagnon Tri-State Area Forum 15 06-03-2001 06:40 PM
('93-'01) i-club licence plate surrounding/cover tmat3 Impreza Forum 6 05-21-2001 01:19 PM
('93-'01) licence plate Qs. Akiata Impreza Forum 3 04-26-2001 07:49 PM
Put on my licence plates this weekend! redobs New England Impreza Club Forum -- NESIC 12 04-17-2001 12:25 AM
Licence plate frames Daios Interior & Exterior Modification 6 03-13-2001 06:11 AM
