Old 02-04-2005, 12:21 AM   #1
popnfresh
Member#: 72832
Default Weird clunking noise from the rear of the car.
When I reverse out of my driveway I hear a clunking noise from the rear as I slow to a stop and put it in 1st. What could e causing this . 05 sti, 200 miles on the clock. thanks.
ive made sure the spare, jack and tool pouch were secure.
popnfresh is offline   Reply With Quote
Old 02-05-2005, 12:52 PM   #2
WRXRgr
Member#: 54942
2004 WRX
If you're still rolling back when you put it in first, and let it engage, you're putting a lot of stress on the whole drivetrain...not good. You're probably hearing your rear diff twist around in it's mounts from the opposing torques. Be sure you've completely stopped the vehicle's rearward motion, before *engaging* 1st...
WRXRgr is offline   Reply With Quote
Old 02-05-2005, 01:17 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
uh thats not a lot of stress on a manual man, i think theres a hell of a lot more stress doing launches
but most likely it is the diff or the tranny, mine made all KINDS of funky noises till i put the sti tranny mount in <dont know if its differnt than the one on the v8 sti> and its gone
alex
Old 02-06-2005, 08:49 AM   #4
WRXRgr
Member#: 54942
2004 WRX
That's like saying sticking your self in the eye with a screwdriver isn't really that bad, compared to jacking off with a handful of razor blades.
Old 02-06-2005, 03:07 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
um well
i rode home with my uncle about 100 times when i used to work for my family
hed always be doing 10 mph in reverse and put it into 1st in his toyota and no he didnt pop a wheel, and that car has over 200k miles on it and its running fine
you realize theres as much if not WAY more stress starting off on a steep hill right?
its not like the car weighs 33485439587398754 lbs
Old 02-06-2005, 04:41 PM   #6
LowUFO
Member#: 36495
2004 WRX
Black Pearl
Try rolling out and not putting it into gear when you stop. Just stop the vehicle and see if it clunks. Because if so, maybe your rear swaybar needs tightening.
LowUFO is offline   Reply With Quote
Old 02-06-2005, 05:13 PM   #7
Jpapania
Member#: 61202
2004 WRX Wagon
WR Blue
If it is making noise when driving over bumps and such, I would agree on the rear sway bar angle. Crawl underneath and shake the bar as much as you can. You hear the noise you know your problem.
Jpapania is offline   Reply With Quote
Ticking noise coming from the rear of the car, need some clues please sjrhee Transmission (AT/MT) & Driveline 5 06-06-2006 05:50 PM
Clunking noise from the rear of the car popnfresh Warranty Issues & SOA Problems 32 03-18-2005 09:30 PM
Weird clunk noise from transmission volkl23 Transmission (AT/MT) & Driveline 2 12-13-2004 03:52 PM
Clunking noise from right rear on 04 STI Alfaneggio Brakes, Steering & Suspension 4 09-18-2004 03:33 AM
weird clunking noise from back right wrx_snobordr Service & Maintenance 18 05-19-2004 01:32 AM
