Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Old 02-04-2005, 06:30 PM   #1
prelude/2.5rs
Member#: 9355
2007 Infiniti FX35
2008 Mazda3 Hatch GT
Question Do I have to pull DRL relay for UK300's...
Hey guys!
I was just wondering if I had to pull the DRL relay under the dash, on the passenger side in order for my UK300's to work correctly. I will be using a bulb adapter to work the lights. I'm not doing the "2 relay set-up" to get optimal lighting. I did disconnect the DRL module under the hood, but never pulled the relay. Does this have to be done and if so, can someone provide me a link to which fuse it is? I remember seeing the post but lost it. Thanks guys!
Mike
prelude/2.5rs is offline   Reply With Quote
Old 02-04-2005, 06:41 PM   #2
Handsdown
Member#: 29355
no fuse, plug under glove box... and from my memory of the wiring diagrams, yes it will be cleaner circuitwise if not necessary.
Handsdown is offline   Reply With Quote
Old 02-04-2005, 09:26 PM   #3
prelude/2.5rs
Member#: 9355
2007 Infiniti FX35
Old 02-04-2005, 11:27 PM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
if you want to keep the DRLs you can, you just need to rewire the lamps. thats what i did with the ones i had.
Shane
PARANOID56 is offline   Reply With Quote
upgrade form TD04 to VF39,do i have to get another inlet for vf39 or use stock one? pengmao Newbies & FAQs 14 02-07-2008 08:53 PM
Do I have to buy new gaskets for... dallas_wrx_blue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-08-2002 07:44 PM
Why do ECU's have to be sent in for reflashing vs a ECU sent to dealer? BIGSKYWRX Warranty Issues & SOA Problems 4 05-25-2002 10:43 AM
do you have to lower your compression for a turbo? pimpomtic Normally Aspirated Powertrain 8 01-18-2001 12:22 AM
