Old 02-04-2005, 09:27 PM   #1
Lachlan
Member#: 19470
1981 Brat GL
Default Switch bulbs
So I managed to burn out all four of the wee bulbs in my fog light and cruise switches. Where does one find replacements? The dealer said they only sell the whole switch for $32. I checked radio shack, autozone, and meijer and nobody has these bulbs!
Lachlan is offline   Reply With Quote
Old 02-05-2005, 09:25 AM   #2
DtownIan
Member#: 31447
'82 Volvo 245
turbo/intercooled/4-spd
I should like to know also--bump!
DtownIan is offline   Reply With Quote
Old 02-05-2005, 11:53 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
ummm...
for the fog light - go to the dealership
cruise? you cant replace the bulbs.
you have to buy a new switch.
IIRC only the fog light switch has bulbs which can be replaced.
just did my fog switch 2 weeks ago....
now my hazard and defrost are out.
i have to buy new switches which sucks, but that's life eh?
Jamie
www.subiegal.com
Old 02-05-2005, 01:19 PM   #4
Lachlan
Member#: 19470
1981 Brat GL
This is for a 99 RS if that makes a difference, but I pulled them apart and the bulbs are the same. I went to the dealership and they said I have to buy the whole switch. Maybe i'll try another dealership or something
Old 02-05-2005, 01:41 PM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
i have an 01 RS - so we're in the same boat
fog switch bulbs can be replaced
hazard - no
defrost - no
but,
i have not pulled my cruise switch out and eyeballed it ....
if they're the same, and you're positive
buy fog bulbs and install them into the cruise switch?....
Jamie
Old 02-05-2005, 04:16 PM   #6
Lachlan
Member#: 19470
1981 Brat GL
I went to the junkyard today, they only have two subies: an old L and a legacy wagon. But I snatched two cruise switches and a defroster switch. Even though the legacy button faces were different the entire assembly was the same for all of them. Unfortunately of the 6 bulbs I took out of them only three worked, so I'm still one short. The switches were $2 each, btw, take that $32 dealership switches!
Jamie--where did you buy the wee bulbs and for how much? My dealer won't sell them separately.
Old 02-05-2005, 05:08 PM   #7
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Pretty much all of the bulbs in the switches are wire-ended 12V miniature bulbs threaded into some sort of switch-specific base - you can pull the bulb out and replace it with something similar - as an example, if you look in the hazard switch, there is a little bulb in a rubber holder which you can remove (just un-thread the wires) and replace. This is a pretty common thing to have to do in older cars (I've done it myself for a number of applications) when the lights in the dash burn out. As long as you can pull the switch apart and get to the bulbs, there is no reason to shell out $30 for a new one.
Old 02-05-2005, 09:56 PM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
i got the bulbs at work
aka Carter subaru
aka allsubaru.com
if you cant find any, ping me and i'll help if i can
Jamie
Old 02-06-2005, 12:02 AM   #9
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
ok, dont mess with lame bulbs anymore, just get some LEDs, wire in the resistor, and you will be set for like 30 years
Shane
PARANOID56 is offline   Reply With Quote
Old 02-06-2005, 12:05 AM   #10
Lachlan
Member#: 19470
1981 Brat GL
I tried some leds, but the only ones small enough to fit were too weak. I'd rather just buy a bunch of bulbs and be set.
Old 02-06-2005, 01:20 PM   #11
PARANOID56
Member#: 22035
2003 Brocoma DCab
too weak? damn man. just use some 5000mcd 5mm leds, and they will be brighter then stock
Shane
Old 02-06-2005, 01:46 PM   #12
Lachlan
Member#: 19470
1981 Brat GL
will 5mm fit? There's such limited space in there.
Old 03-21-2005, 09:06 PM   #13
andygold
Member#: 7347
2002 Impreza WRX
WR Blue
I've had to replace all four bulbs on my 2002 WRX's Cruise control and fog light switches.
Don't know if other model years are the same, so obviously...use at your own risk.....
Radio Shack "Micro Lamp" #7219. The other number on the package is 272-1092. It's $1.49 per package of 2 bulbs. They are shorter in length than the stock OEM bulbs, but fit right in, and provide the same amount of light. I've been using the first ones I put in for over a year with no problems (same specs as stock AFAIK).
They are speced at: 12 volt, 60ma, wire-terminal base
andygold is offline   Reply With Quote
Old 03-23-2005, 10:54 AM   #14
kingsubi
Member#: 19239
2011 WRX
cheers - even available at radio shack canada..
kingsubi is offline   Reply With Quote
Fog Light Switch/IC Spray Switch Bulb Change Question! sauuce Electrical & Lighting 0 02-21-2007 05:15 PM
Fog Light Switch Bulb P/N wagons_ho! Electrical & Lighting 0 11-12-2003 04:16 PM
fog/cruise/defrost/hazard switch bulbs NateDogg Electrical & Lighting 1 05-11-2003 03:37 PM
Fog switch bulb LVSUBARU Service & Maintenance 7 11-10-2002 07:53 PM
Defroster/Foglight Switch Bulb Keith99RS Legacy Forum 4 12-30-2001 09:56 PM
