Old 02-05-2005, 01:45 AM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default EJ20G head gasket
Alright, so I've heard that you cannot use the EJ207 head gasket on the EJ20G for a few reasons. On Cometics website, they list those 2 engines together. What is the truth? Who sells an aftermarket head gasket for the EJ20G? Thanks.
Brent
scoobyimprza is offline   Reply With Quote
Old 02-05-2005, 03:00 AM   #2
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Has to do with piston potrusion height. I used the 207 gaskets on my engine, but I had different pistons and rods.
Best replacement gaskets for the earlier EJ20's is the steel ones from a V3,4.
Ver.III is offline   Reply With Quote
Old 02-05-2005, 08:44 AM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Any idea where to get one? Wouldn't a Cometic 103mm gasket be thick enough?
Old 02-05-2005, 10:09 AM   #4
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
I know zerosports makes them up to a 1.8mm tomei might make them as well.
DuoMaxwell is offline   Reply With Quote
Old 02-05-2005, 02:21 PM   #5
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
a dealership in new york has one set left of ej20g head gaskets... give me a pm for more info.
Rick
scoobydorift is offline   Reply With Quote
Old 02-05-2005, 10:59 PM   #6
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I'm not looking for anything immediately, just searching the market. The Tomei head gasket is $350. I also emailed MRT to see if they had anything.
Old 02-06-2005, 05:11 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
If you know what you need, Cometic will make a set to suit you. Contact them and speak to them directly....
Jay Storm
Old 02-06-2005, 07:50 PM   #8
Ver.III
Member#: 1185
I flap my gums
I ordered the V3/4 stock steel gaskets from Japan. It worked out to about $40 Cdn each. I don't have that connection anymore but there is another company , IRS that does exporting parts from Japan.
Old 04-06-2005, 11:49 AM   #9
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
does anybody have the part numbers for the EJ20G head gaskets?
AsphaltsCry is offline   Reply With Quote
Old 04-06-2005, 01:47 PM   #10
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Ive got the part numbers at home for the entire gasket set for a ej20g. I will post them up when I get home.
Thanks
Rick
RallySport Direct is offline   Reply With Quote
Old 04-06-2005, 03:22 PM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The EJ20G gasket is .152 cm, like all the other phase I engines. You can actually use an EJ22T gasket on it if you are in a pinch. That's what we used on Bugman's EJ20G w/EJ22T heads...
Old 04-06-2005, 05:31 PM   #12
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
if you do a search you can find infro on the gasket...
i did a couple of compresion checks w/ diff. subaru heads/blocks/headgaskets. i also postd the CC the gasket holds and what not.
just search it and u will find it...
EJ20G head gasket is at least 3X thicker then the EJ205...i would look for it for you but im to lazy
snowman4us is offline   Reply With Quote
ej20g headbolt torque specs/head gasket question snowjob Subaru Conversions 1 03-31-2014 03:19 PM
ej20g head removal\ gasket replacement, engine out! shatowz Subaru Conversions 6 01-18-2006 06:21 PM
Q: EJ20G heads vs. MY98 DOHC EJ25 Heads Kostamojen Subaru Conversions 49 01-30-2005 07:54 PM
Help! FAST! Do I need to use gasket sealer, when replaceing my head gaskets?! wighti Tri-State Area Forum 5 10-05-2003 11:19 PM
Leaky Head Gasket & Water Pump Gasket - MY00 Forester lark6 Normally Aspirated Powertrain 20 11-10-2001 11:22 PM
