Old 07-13-2001, 03:52 PM   #1
Blindeye_03
Member#: 4418
2016 Focus ST
Default t3 vs t3/t04b
What is the difference between those two turbos?
thanks,
-justin
Blindeye_03 is offline   Reply With Quote
Old 07-13-2001, 04:33 PM   #2
SubaFastR
Member#: 5786
a t3/t4 is a hybrid turbo. it uses a t3 exaust side, and a t4 (bigger) for the compressor. The reason is the fast spooling of the t3 and the big airflow of the t4.
SubaFastR is offline   Reply With Quote
Old 07-13-2001, 04:57 PM   #3
atlien
Member#: 5396
I've got a t3/to4e sitting right here on my desk. The to4 series compressors will get you alot more hp than the t3 compressor, but at the cost of more lag.
atlien is offline   Reply With Quote
Old 07-13-2001, 05:49 PM   #4
Blindeye_03
Member#: 4418
2016 Focus ST
So does the t3/t04b lag more or spool faster?
Old 07-13-2001, 08:06 PM   #5
atlien
Member#: 5396
The t3/to4b setup will (generally) be less laggy than a full t4 or a t3/to4e setup but more than a full t3. It would also be good to know the wheel trim and housing A/R. You have to trade power potential for lag in most cases. This is really to big a subject to explain fully here. Do a search on turbo selection or better yet do the same search over on the rx7 or supra boards. I've got an article from Hot4s magazine from Australia that actually explains most of this for Subaru upgrades, but no scanner. Turbo magazine has had a really good article on picking a turbo for the past two months (first two in a series) that is really good at explaining it as well, right down to using compressor maps. Damn I need a scanner!!
T4 vs T3... nomorem3 Normally Aspirated with bolt-on Forced Induction Powertrain 1 07-26-2006 04:10 AM
t4 vs t3/t4 2RXS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 05-03-2004 02:18 PM
VF30 vs T3/T04E VIMOTA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-11-2004 03:28 PM
gt25 vs t3/to4 chaos_nite Normally Aspirated with bolt-on Forced Induction Powertrain 9 11-28-2001 12:28 PM
T3 and T3/T4 hybrid imprezive Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-31-2001 05:03 PM
