Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-05-2005, 07:03 PM   #1
Lachlan
Member#: 19470
1981 Brat GL
Default Ohm's law guru's: Help me pick the proper resistor
If I want to stick an LED with 2.5V max potential rating on it into a hole where a 12v light bulb went, what resistor do I need? I'm not sure what the current is, this is for the tiny little fog/cruise type button switches.
Lachlan is offline   Reply With Quote
Old 02-05-2005, 07:13 PM   #2
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
A 1k ohm will work fine.
Scoobie Steve is offline   Reply With Quote
Old 02-05-2005, 07:35 PM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
use this to calc your own resistors:
http://ourworld.compuserve.com/homep...Bowden/led.htm
Keep in mind though that when the vehicle is runner, the alternator keeps the voltage a 13.8-14.2 and not 12V. If you can't find a resistor of the exact value calculated, always use a higher value to be sure you don't overvoltage your LEDs.
nhluhr is offline   Reply With Quote
Old 02-05-2005, 07:49 PM   #4
Lachlan
Member#: 19470
1981 Brat GL
Thanks, but the problem is I'm not sure what the current is through the illumination stuff.
Old 02-05-2005, 09:10 PM   #5
UKscooby
Member#: 33287
RIP Nik
I will always miss you
OK.
Assume 14.2v max.
Assume 15mA max for the LED.
V=IxR
I=V/R
R=V/I
14.2v - 2.5v = 11.7v (you need to drop 11.7v through the resistor to get your 2.5v forward voltage for the LED.
So...
R=11.7/0.015
R=780 ohms
Find the closest match to a 780 ohm resistor.
Power rating...
P=I^2 x R
P=0.015 x 0.015 x 780
P=0.1755W
You will need a 1/4W resistor (1/4W = 0.250W)
UKscooby is offline   Reply With Quote
Teh OT: Help me pick the new HD TV for my house! cucamelsmd15 Off-Topic 18 10-08-2006 07:43 PM
Help me pick the smarter option re: turbo wrxfactor Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 05-30-2006 08:14 AM
help me pick the perfect size tire. blackie Tire & Wheel 6 01-20-2005 02:52 AM
Help me pick the right mac setup please scaryfastskier Off-Topic 25 01-07-2003 06:45 AM
Help me pick the best All-Season tire? balajc Brakes, Steering & Suspension 16 04-03-2002 04:29 PM
