Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 02-05-2005, 07:37 PM   #1
Kayakertom
Member#: 78552
89xt-4,87dl wag
Default Crankshaft pulley bolt removal?
I'm having a big problem trying to remove the crankshaft pulley bolt on my ea82 motor with manual transmission. Can someone describe or post a picture of the tool that is used to lock the flywheel?
I have tried bumping the starter with a blocked wrench on the bolt to no avail. Have also had it in gear with the parking brake on, but still can't undo it.
Thanks,
Tom
Kayakertom is offline   Reply With Quote
Old 02-05-2005, 07:59 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
put tranny in gear with e-brake on and give her hell man, she'll move with a 3 ft breaker bar trust me, unless oyur like 40 lbs or something, remember to torque it down to factory specs afterwards.
~Josh~
Old 02-05-2005, 11:45 PM   #3
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
I have a small hole drilled into the top of the bellhousing. It lines up with the hole in the flywheel. I simply drop an old phillips screwdriver through the hole and away we go.
Calebz is offline   Reply With Quote
Old 02-06-2005, 03:15 AM   #4
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
this prob. won't help much, but here's the ultimate tool for the job.......http://buy1.snapon.com/catalog/item....re&dir=catalog
00Maddog is offline   Reply With Quote
Old 02-06-2005, 02:50 PM   #5
Kayakertom
Member#: 78552
89xt-4,87dl wag
Smile Mission Accomplished - Thanks Calebz
I drilled the hole directly behind the access hole for accessing the timing marks on the flywheel. Put a moistened rag through the access hole to collect the drill shavings. Started drilling perpindicular into the angled surface of the bellhousing and then finished the hole straight up directly in line with the flywheel hole position. With a phillips screwdriver through the newly drilled hole and into one of the flywheel holes, which locked the flywheel in place, the crankshaft pulley bolt came loose easily with my 22mm socket - 1/2" drive & 16" long breaker bar.
Calebz, I owe you a beer.
Old 02-07-2005, 12:49 PM   #6
Calebz
Member#: 54398
1980 CB400 Hawk
Glad it worked out for you.
Wish I could claim that bit of brilliance as my own, but I learned it from another soob nut in the northeast.
crankshaft pulley bolt install question kmook Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-17-2010 09:29 PM
Homebrew crank pulley bolt removal setup? Broxma Built Motor Discussion 5 04-05-2008 12:04 AM
88 subaru GL crankshaft pulley bolt size red86aw11 'Old School' Subaru Forum 7 07-29-2004 08:10 PM
Broken crankshaft pulley bolt alent Normally Aspirated Powertrain 1 05-31-2004 09:27 PM
Removing crankshaft pulley llonman Technical Forum Archive 9 08-28-2000 01:23 PM
