Old 02-05-2005, 07:52 PM   #1
culmination
Member#: 57065
2004 GT35R STi
Default a/f gauge
my autometer A/F gauge was taken out from my accord several years ago and it has been untouched since then... i decided to install this and did a little of bit of research and i found out the correct wire to tap is the rear oxygen sensor (b137 #25) from the ECU pinout. after i installed the gauge i decided to take my car out for a spin however when i started up my car the guage was showing "lean.." for crusing it was "stoich" and WOT was "rich" when im back to idle it goes back to "lean." should i be concerned that my idle is "lean?" also, the reading is not that fast, i would say that there is about 1~2 sec. delay.....im wondering rather or not
A. i didn't install it properly
B. the guage is broken
C. i installed everything correctly and the gauge is not broken... so .my car is lean at idle
one more thing... i installed my UTEC couple of days ago (untuned) with blitz SUS intake. i will get it tuned as soon as i install my APS 3" TBE.
thanks~
culmination is offline   Reply With Quote
Old 02-05-2005, 08:26 PM   #2
import111
Member#: 24447
2016 Mustang GT w/PP
Red
I had an Autometer A/F gauge on my old 01 2.5RS-T and it had a 1-2 second delay also. I guess it is normal. I don't think it is hurting anything to run lean at idle. My old car ran lean at idle sometimes. I am not sure what STI's A/F's are suppose to be. I am pretty sure they are suppose to run a little rich on boost, but that is all I know.
Ryan
import111 is offline   Reply With Quote
Old 02-06-2005, 11:11 PM   #3
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
would the intake have anything to do with the lean condition?
wrx05 is offline   Reply With Quote
Old 02-06-2005, 11:22 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Installing an AF gauge to the stock o2 sensors(NOT wideband) is useless.
Just a pretty, flashy, blingy, gauge.
Old 02-06-2005, 11:23 PM   #5
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
An autometer a/f gauge is best left in the back of a closet somewhere. Its just not a very good gauge. It mostly just blinks differnt lights in correlation with the position of your left foot.
afpdl is offline   Reply With Quote
Old 02-06-2005, 11:24 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 02-06-2005, 11:34 PM   #7
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Ive been up for too long.
But the gauge still sucks.
Old 02-07-2005, 11:04 PM   #8
import111
Member#: 24447
Red
Actually my Autometer A/F gauge helped me out quite a bit. It definatly let me know when my car was acting up and having problems. I agree that a wideband setup is more reliable. The regular A/F gauges still work though.
Ryan
Old 02-07-2005, 11:14 PM   #9
veightkiller
Member#: 78967
2011 335i
it's still work but not that accurate though... wideband is the best way to go..
budget....budget....budget....<---------this will be the probelam then...
veightkiller is offline   Reply With Quote
Old 02-08-2005, 02:58 AM   #10
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Ryan
no it really doesn't tell you ****. There is absolutely no useful information, either from a tuning standpoint, or a "is my car running okay" standpoint that can be had from a narrowband O2 sensor. it's not a matter of wideband being more accurate or more reliable - it's a matter of the wideband showing the information that you need and a narrowband NOT showing that information.
A narrowband (like the autometer) only has a useful range from just barely lean to just barely rich. To accurately judge if you car is running well or even to tune, you need RESOLUTION in the 10-12 range and the narrowband doesn't read in that range at all.
Then there's the issue of the narrowband being installed on a sensor that is downstream of two cats which further negates any usefulness.
If you are watching an autometer air/fuel gauge and you feel like it's giving you useful information, it is quite simply a false sense of security and in reality you have no clue whatsoever what is going on.
Uncle Scotty has it right when he says it's "Just a pretty, flashy, blingy, gauge." It has absolutely no practical purpose, tells you absolutely no useful information, and has no place in a WRX or any other turbo car with modern electronic fuel injection.
nhluhr is offline   Reply With Quote
Old 02-08-2005, 10:50 AM   #11
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
It may be able to tell you if your rear cat has dissapeared though.
Old 02-08-2005, 11:55 AM   #12
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Old 02-08-2005, 08:56 PM   #13
import111
Member#: 24447
Red
If the Autometer A/F gauge is useless then why when my car went so lean that it bucked me forward did the A/F gauge show a lean spike every time that happened. Seems to me it worked just fine. And when my car ran good, the A/F gauge showed 1-2 bars into the rich. When my car didn't feel as fast the A/F gauge would show way lean under boost.
Ryan
Old 02-08-2005, 10:49 PM   #14
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
if your car is running "good" it should be PEGGED into the rich, not just 1-2 bars.
Old 02-09-2005, 12:13 AM   #15
import111
Member#: 24447
Red
pffffff, it is not good to run too rich. It will keep the EGT's low sure, but kill power running overly rich. The car was a 01 2.5RS w/ a stg 3 turbo kit. 2 bars into the rich was rich enough to keep detonation away and make good power. Even when it ran stoich at WOT on full boost it never detonated or anything. Pegged rich is not running good.
Ryan
Old 02-09-2005, 03:38 AM   #16
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
thing is, the autometer gauge only reads down to about 12.5:1 at the richest end of its scale... for it to not be all the way there indicates that your tune is nowhere near "good"
I do know a thing or two about engine tuning. After all, I keep a Wideband kit in my car 100% of the time, i've had UTECs, etc...
FS : 2005 Stock exhaust, shift knob SUPER CHEAP infinite012 MAIC Private Classifieds 26 07-09-2010 08:21 AM
52mm STRI gauges- price drop TheNailman NESIC Private Classifieds 82 06-24-2010 06:00 AM
52mm STRI gauges- Price Drop TheNailman Exterior/Styling 111 06-24-2010 05:58 AM
FS : Meth / water injection kit NEW! defi gauges boost, egt JT's06sti Engine/Power/Exhaust 7 06-17-2010 11:45 PM
Gauges, gauges and more gauges arrghh! trustWRX Newbies & FAQs 2 08-25-2003 12:43 PM
