Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 02-05-2005, 10:19 PM   #1
Lachlan
Member#: 19470
1981 Brat GL
Default Crap! Fried something and now car no worky
What I did wrong:
I was trying to check the current through a bulb, but instead of putting the ampmeter in series with the bulb, I put it in parallel. Oops!
The result:
The voltage for the "on" position is still 12V (well 10v with the engine off) but when I turn the key to start it just makes a clicky noise like a relay opening and closing, but the car doesn't turn over. All the fuses seem to be intact.
Please help me!
Lachlan is offline   Reply With Quote
Old 02-05-2005, 10:27 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you are only seeing 10V at the battery with the engine off, it's dead and that's why it won't start assuming no critical fuses are blown. Are you sure they're all good, including the large main fuses under the hood?
Old 02-05-2005, 10:29 PM   #3
Lachlan
Member#: 19470
1981 Brat GL
I checked all the minis with a checkerator and they're good. The bigguns have a window on top and they all seem to be intact. 10v is a dead battery? It was just fine until I shorted it--it seems like a fuse would have blown but it didn't...
Old 02-05-2005, 10:36 PM   #4
R_W
Member#: 76896
If you shorted at a bulb socket, worst case I think you would mess up the bulb circuit. Will the bulb come on? If so there's probably no damage anywhere.
I think Mulder's right, it's the battery.
RW
R_W is offline   Reply With Quote
Old 02-05-2005, 10:39 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The battery was probably not "fine", it was marginal and the sudden high drain from the short killed it. Just an educated guess since I'm not actually there to look at it.
A good, charged battery should read 12.5V at rest with the engine off.
Old 02-05-2005, 10:43 PM   #6
Lachlan
Member#: 19470
1981 Brat GL
doh! It was the battery. A jump started it right up. I didn't think shorting a wee light socket could have such a profound effect.
Old 02-05-2005, 10:58 PM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
99 rs... is that the original battery?
if so.. it's probably time for a new one
Jamie
Old 02-05-2005, 11:00 PM   #8
Lachlan
Member#: 19470
1981 Brat GL
I'm not sure if it's the original--I bought it at 103K. But when I have some spare dough I'm going to get a light weight battery.
Old 02-05-2005, 11:07 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Well since the battery is dead NOW, I don't think you should wait until you've saved up for a new one. Personally I'm not a fan of lightweight batteries for street cars, the weight savings isn't worth the compromise in performance, particulary reserve capacity. Unless the car is used for competition where those few pounds, and the weight distribution will really matter, you're better off with a full-size battery. For maximum reliability an Optima is the ticket, but if you're on a budget even the cheapest standard battery from Wal-Mart will be better than the dead one you have now.
Installed 03 WRX Momo Steering wheel in 06 2.5i. Now horn no worky. skribblez32 Electrical & Lighting 2 07-19-2012 12:25 PM
Reverse and cruise control no worky C-Rock Electrical & Lighting 1 09-04-2007 02:12 AM
So I say no to joining his Amway scam and now we're no longer friends nos Off-Topic 92 10-10-2006 12:35 PM
Got new tires and an alignment and now car is hunting? sisenor Brakes, Steering & Suspension 1 09-22-2005 02:09 AM
prodrive I/C hoses and now car smokes eatus ravenous Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 01-15-2005 10:38 AM
