Old 02-06-2005, 12:17 AM   #1
Hola
Member#: 80082
Default Camshaft Position Sensor (Car won't start)
Hi, I have a '93 Legacy 2.2L NA. The other morning I went out to start it and it wouldn't start. It had run fine the night before. The engine turns over and the spark plugs are getting spark and the fuel pump is delivering fuel. I then decided to check the car's computer and see if it was of any help. I connected the little diagnostic connectors under the dash and flashed the CEL. The trouble codes it gave me were for the #3 fuel injector and the camshaft position sensor. I don't think having one fuel injector out would prevent the car from starting, it would just make it run rough, right? After thinking about this I looked in my manual to see how to test the camshaft position sensor. It said to disconnect the harness from the sensor, hook a multimeter up to it and turn the engine over. The output from the sensor should be around 0.1 volts, varying in time with the engine turning. I did this and I got a reading of 0.2 and 0.3 volts varying back and forth as the engine turns. Occasionally the voltage would drop down to 0.1 for a moment but it stayed mostly at 0.2 and 0.3. My first thought was that the sensor must be okay because the reading was only one to two tenths of a volt off of what the specifications are. But then I got to thinking about it more and I realized that although thats only one to two tenths off normal, it is also two to three times what it should be. I guess what I'm getting at is is this a very sensitive sensor? Can a small difference in voltage cause trouble? I searched in old threads trying to find something out about this but was unsuccessful. Also, even though I'm getting spark does anybody think that there could be a problem with the coilpack/ignitor? For example, maybe it's giving spark, but not at the right time? If the car had died while running I would suspect the timing belt but since it just won't start I don't know what to think. Thanks for any help you folks can give me.
Hola is offline   Reply With Quote
Old 02-06-2005, 03:11 AM   #2
scottyP
Member#: 59829
2002 WRX wagoon
wrb
Default cmp
i had trouble starting my 2.2 because the cam postion sensor. it was a recall part for 95's though, maybe the 93's also, and it did fix the problem right away. you should find out from your local subaru dealer and its freee
scottyP is offline   Reply With Quote
Old 02-06-2005, 03:05 PM   #3
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
with the cam or crank sensor disconnected, the car will NOT start at all. I did a test on my MY99 for probable failers.
FuJi K is offline   Reply With Quote
Old 02-06-2005, 04:20 PM   #4
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
The cam position sensor and crank position sensor come in a set. From your dealer it'll cost you about $40. I just replaced them on my wifes EJ22 OBS.
nunyo is offline   Reply With Quote
Old 02-07-2005, 01:46 AM   #5
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Can you mess with the cam sensor and pick up any power? I wondered if it might be like turning a distributor....
HamFist is offline   Reply With Quote
Old 02-07-2005, 08:45 PM   #6
Hola
Member#: 80082
No, the camshaft position sensor isn't turnable, it works by magnet or something. I actually ended up replacing it and the car still won't start so now I'm going to have to check the wiring and everything. Sometimes after I turn the key back to "ON" form "START" after turning the engine over there is a strange buzzing/grinding noise that comes from somewhere in the dash on the left side. I'm hoping that I haven't fried any wires. By the way, thanks everybody for your thoughts and ideas. I appreciate your time.
Old 02-08-2005, 01:13 AM   #7
sick1.8t
Member#: 22345
2003 RSX
black
yeah both the cam and crank sensors sense the teeth on the pulleys going by and relay the signal to the ecu. they cant be moved or fooled with in any form.
sick1.8t is offline   Reply With Quote
Camshaft Position Sensor Issue (Car won't start) Hola Service & Maintenance 2 02-06-2005 12:12 AM
Camshaft position sensor dead AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 3 01-16-2004 05:30 AM
Camshaft Position Sensor ehabs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-31-2003 03:06 PM
Camshaft Position Sensor zsurfrin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-16-2002 10:00 PM
CEL code: 0340 / Camshaft position sensor BluJay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-06-2001 05:07 PM
