Old 02-06-2005, 05:00 PM   #1
Jpapania
Member#: 61202
2004 WRX Wagon
WR Blue
Question Help on Modifying Stock IC Splitter
What I am wanting to do is modify the stock splitter on my WRX to better work with the 04 Sti hood scoop I added. I would like to extend the metal piece so it come in contact with the inside of the scoop. Anybody done this before? What materials should I use and where should I get them? If you have measurements of how much I need to extend the piece by that would be very helpful.
I know what some of you are thingking, just get the Sti part and safe myself and lot of time. Problem is I still have the stock intercooler and would rather use the stock part since it fits around the intercooler and does not let air blow buy.
I also always like to have a back up piece, so does anybody know the part number for the stock work splitter piece? Thanks,
Jpapania is offline   Reply With Quote
Old 02-06-2005, 05:41 PM   #2
quazimoto
Member#: 70395
I just cut the top away from the sides until about 1/2 " from the bottom with a jigsaw and bent the whole top up about 2".Then i used some HVAC "silver"tape (not duct tape) to act as a filler in the side gaps.Just taped it on both sides,inside and out.The tape is thin,very strong,and very sticky.Works great on my STI scoop.
quazimoto is offline   Reply With Quote
Old 02-06-2005, 06:43 PM   #3
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
I ordered the Zerosports "replica" splitter from MPJ. Nice stainless steel part but its 8 pounds! I drilled all the spot welds and took it all apart. I went to a local metal fabrication shop and had all the parts lazer cut in aluminum. With a brake press and tig welder I was able to recreate it. You could do the same with rivets instead of spot welds.
You can do like the above post and make it work but I wanted a OEM appearing part. You will need to cut a pie shape out of the sides to raise the rear part of the scoop and then make atleast one plate to direct air to the front 1/2 of the IC.Then rivet it together and even finish the pie cut with fiberglass mat. Depends on how far you want to go.
BVM is offline   Reply With Quote
Old 02-06-2005, 08:30 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Watch eBay for the zerosports splitters - they turn up from time to time (I picked mine up for $100 brand new from Rennick Subaru, but it's for an 02/03 stock scoop) - the Zerosports ones weigh about the same as the stock splitter (mine did, anyway - surprisingly light) - the replicas appear to be much heavier (probably thicker gauge material).
Old 02-07-2005, 01:13 AM   #5
SleepinRex
Member#: 12449
SleepinRex is offline   Reply With Quote
fs.IL- stock sti headers&uppipe,stock IC splitter STiGMATA Engine/Power/Exhaust 6 06-10-2008 05:01 PM
Anyone have an opinion on modifying stock wrx injectors? chosen_cartel South West Impreza Club Forum -- SWIC 25 10-08-2007 10:55 AM
02-03 interior pieces and stock IC Splitter NothnButTheFacts Interior/Dressup/Audio & Security 13 07-11-2007 11:52 AM
Nos on my stock IC avengermike Water/Methanol Injection, Nitrous & Intercooler Cooling 14 10-07-2005 09:15 AM
Stock IC Splitter dunk Mid Atlantic Impreza Club -- MAIC 20 02-19-2005 08:19 AM
