Welcome to the North American Subaru Impreza Owners Club Thursday May 7, 2015
Old 02-06-2005, 11:50 PM   #1
Jyik40
Member#: 48540
2005 Spec-V
Sapphire Blue
Default 2004 RS Headgasket
I just finished installing an OEM oil cooler and I noticed that there was some moisture where the head meets the engine block (passenger side).
When I replaced my coolant I made sure I poured in the "Subaru Coolant Conditioner" in to the radiator. I thought the moisture would go away after driving around a bit but it is still moist in that area. It doesn't seem to be a big leak but it is always wet to the touch. The wet spot looks a little black (I'm guessing that it is the headgasket's material bleeding out).
I know this is a common problem with the open deck block on the EJ25 engines, but is there a need for me to worry? Should I take the car in to the dealer and ask for them to replace one of the head gaskets? (my car has almost 20,000 miles on it) I don't mind the small leak as long as it doesn't lead to complete headgasket failure.
Thanks for reading...
Jay
Jyik40 is offline   Reply With Quote
Old 02-07-2005, 12:59 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
"Moisture" meaning coolant????
I think you are seeing ghosts.
Uncle Scotty is online now   Reply With Quote
Old 02-07-2005, 07:51 AM   #3
Jyik40
Member#: 48540
2005 Spec-V
Sapphire Blue
I must of been very tired last night. Yes, I mean coolant. I have no idea why I wrote "moisture". Yeah I have the common leaky headgasket.
Jay
Old 02-07-2005, 08:05 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
If you have the 'common leaky headgasket' it would be internal to the engine, and you would have other issues.
This is a fairly uncommon issue in the phase 2 engines unless it has been overheated.
....and what is this 'oem oil cooler' that you installed and why???
Old 02-07-2005, 09:10 AM   #5
Hayes
Member#: 11808
Some Phase 2 engines experience HG weepage. The "conditioner" usually fixes this but it is not a pour it in and the weeping is gone. It takes many hot cold cycles for the conditioner to work because it depends on the conditioner getting through the leak area. This may take many hundreds of miles and many weeks. Just keep an eye on it at each oil change and if it continues contact your dealer. This seems to be a common problem with many makes and some manufactures are puting in the conditioner in at the factory. Ed
Hayes is offline   Reply With Quote
Old 02-07-2005, 11:21 AM   #6
Jyik40
Member#: 48540
2005 Spec-V
Sapphire Blue
Uncle Scotty:
The OEM oil cooler is the one that is found on the WRX's and the Automatic Forester Models. The main reason I put it on my car is because sometimes I have to make short trips when it is very cold outside (I live in NY). This helps heat up the oil to operating temperatures a bit faster. It also helps cool the oil when I am sitting in NYC traffic.
Ed:
From what I understand, the coolant additive was already installed at the factory on the 2004 models. I just added it again because I flushed my coolant and the service manual also states that it must be added everytime the coolant is drained. I made an appointment with my local dealer just to keep it on record.
Thanks for your help
Jay
2004 RS 5MT into 2001 RS 5MT? BlackfeetVI Transmission (AT/MT) & Driveline 1 10-22-2008 01:48 PM
99 RS Headgasket haloseven Texas Impreza Club Forum -- TXIC 28 04-24-2008 08:21 AM
98 2.5 RS headgasket DBSS_Gohan Normally Aspirated Powertrain 2 09-04-2005 03:30 PM
2004 Outback headgasket issues JPC0005 Service & Maintenance 2 04-29-2005 01:03 PM
2004 RS Suspension Vs 2004 WRX JeffrWRX Brakes, Steering & Suspension 2 10-09-2004 12:45 AM
