View Poll Results: What do you do when changing the oil?
Put on a dry filter, fill crankcase, and start it up. 44 42.72%
Fill filter with oil first, don't notice a difference in oil PSI 48 46.60%
Fill Filter with oil first, it takes longer to get normal oil PSI 5 4.85%
I prime the engine first before starting 6 5.83%
Voters: 103. You may not vote on this poll
Old 02-18-2005, 09:05 AM   #26
fansipans
Member#: 62991
Every document I've read now related to changing the oil on a Subaru states to NOT over-tighten the new filter. That being said, how tight do you guys do your filters? How tight is "Hand Tight", tight enough you could still rotate it further basically?
Do people here have preferences with OEM/Aftermarket filters? Checking scoobymods, there are like 7 different aftermarket filters for the turbo subaru, and fram's filter is even 68mm (instead of the old 80mm)
fansipans is offline   Reply With Quote
Old 02-18-2005, 10:44 AM   #27
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
If you haven't already, read this thread for more Subaru oil filter data than you'll ever need:
http://www.imprezawrxsti.com/postnuk...wtopic&t=16625
Cliff's Notes: the standard Subaru OEM 15208AA080 filter is very good.
Jon Bogert is offline   Reply With Quote
Old 02-18-2005, 01:00 PM   #28
z&cobb
Member#: 12344
2002 2JC
blue
I have owned many high mileage trouble-free cars. I never filled the oil filter, because they were mounted horizontal.
The wrx is the first car I have owned where filling the oil filter with oil was possible. I do it now because I can while the old oil is draining. Plus the wrx is the first car I have owned where I don't have to raise the car to change the oil/filter.
Does pre-filling really help? Probably, if you drain the old oil overnight and there is no more oil film on the surfaces.
So, I do it because I don't like seeing a red oil light come on for a couple of seconds after I start the car with the fresh oil, and I change the oil frequently.
My other cars where this was not possible, ran well over 300,000 miles maintaining tight responsive I6 and V6 engines. Transmissions had to rebuilt, but never the engines, and they were driven hard through the gears.
This is my first performance car with Nikasil cylinder coatings on Aluminum. I have heard horror stories about gas/oil effects on these coatings. Mostly about BMW's in storage. So I do treat the H4 with a little more tenderness that the "bullet proof" I6 and V6. I don't think it can hurt since my H4 works hard putting out more hp than stock.
z&cobb is offline   Reply With Quote
Old 03-13-2005, 08:38 PM   #29
shemoves
Member#: 80663
2005 STi
Basically, turn it 3/4 to a full turn more just after the seal in the filter touches the metal part on the car. In my experience, it works out to be a heavy hand tightening.
shemoves is offline   Reply With Quote
Old 03-16-2005, 12:03 AM   #30
gakusya
Member#: 81982
2005 WRX STI
Crystal Grey Metalic
I don't think pre-filling makes any difference. I am pretty sure, oil will come out from oil filter mount if you pour fresh oil without installing new oil filter.
gakusya is offline   Reply With Quote
Old 03-16-2005, 02:22 AM   #31
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
i usually use oil flush before i drain out all the oil. after the oil is gone and i take out the old filter and clean the gasket it was connected to. fill the new filter with new oil and oil up the gasket again, pop the filter back in and fill up the oil tank.
eltrouble is offline   Reply With Quote
Old 03-16-2005, 05:11 PM   #32
Captain Choad
Member#: 66572
2010 Legacy
silly post minimum for links is making us troll out of teh ot.
Captain Choad is offline   Reply With Quote
Old 03-23-2005, 05:16 PM   #33
cgregson
Member#: 66440
ditto
cgregson is offline   Reply With Quote
Old 03-23-2005, 07:16 PM   #34
hondaeater69
Member#: 60324
Originally Posted by cnk
The more important issue is that you do the oil changes at regular intervals.
Calvin
Best thing said in this thread. This is more important than what type of oil you use, what type of filter you use, whether you prefill your filter or not, or whether you crank prior to starting. . .Just change it when ur supposed to.
Old 03-25-2005, 12:57 PM   #35
STi Guy 69er
Member#: 82648
2005 Impreza 2.5 RS
its jus an oil change. enuff said.
STi Guy 69er is offline   Reply With Quote
New Color Change Method For Interior Lighting choader Electrical & Lighting 2 10-09-2008 08:41 PM
change oil filter with every oil change? BlackBeastie Service & Maintenance 1 03-15-2003 07:29 PM
2nd oil change and which oils to change? makofoto Service & Maintenance 4 12-28-2002 08:07 PM
